COE COE Picture thread (imported from main board)
Discussion in 'Off Topic Hot Rods & Customs' started by Duration, Oct 30, 2007.
  1. vintagehotrods
    vintagehotrods
    ^^^ WOW!!! That thing is going to kick some serious ***!! ^^^
  2. vintage56
    vintage56
    hey LocoBreath, I can't tell from the profile if yours is a cannon-ball? Also, didn't that mill (twin6) come in some 48-54 coe's? Is that the original placement for such?
    Looks great in there!
    JML
  3. Locomotive Breath
    Locomotive Breath
    from Texas
    No, not a cannon-ball, just a standard 1 1/2 ton 350 series. The V12's were only available in trucks from '63 to '65, but there were a lot of them sold for irrigation pump engines as well. This old truck was originally 248 inline six powered.
  4. Baron
    Baron
    Looks good. Do have one question for you. With the motor set that far back, what is the length of the driveshaft?
  5. Locomotive Breath
    Locomotive Breath
    from Texas
    The d-shaft is 14" long. It has bolt in yolks on both ends and I re-used the slip yolk portion of the original shaft so it shouldn't bind with suspension travel.
  6. Baron
    Baron
    Thanks. I hope to be able to shorten my 89 ch***is to let me run a 12" d-shaft. I figure with the number of leafs in the rear springs, the suspension won't have a lot of travel.
  7. Locomotive Breath
    Locomotive Breath
    from Texas
    I like that chopped windshield look. Are you going to do your current COE the same way?
  8. Baron
    Baron
    No. I did that one because there was a serious rust issue at the top of the windsheild. I always regretted not chopping the top instead of "cheating" the way I did.
    I have thought about chopping my new one, but I want to get it mounted on the new ch***is,get it up and running, then I'll give that some more thought. I also want to chop and section my 50 pickup. Once I get my 55 G***er finished,I'll choose the next "victim". It's all fun
    (and great stuff thinking about in the meantime).
  9. Okie Pete
    Okie Pete
    1937-38 International D-series cab over
  10. Casey
    Casey
    yea man I have pictures of that thing it made me want a chopped bus
    I`m not sure I will live long enough to finish mine ?
    I think I might sell it pm me if any one is interested
  11. chopdtop
    chopdtop
    thought this truck looked familiar.
  12. fat57
    fat57
  13. OldSub
    OldSub
    What can you tell me about this one? What frame and suspension does it have? Where is the motor located? What is the wheel base?
  14. hotroddon
    hotroddon
    Interesting COE's but this LUV truck definitely doesn't fit the "Traditional" rules of this board.
  15. fat57
    fat57
    Sorry about that I uploaded by mistake on to many sites a once ..The 48 COE is on a ozzy Frame same as a c10 motor in front 350/350 wheels are 22 inch look and drives better on chev, white walls
    Thank you Mark jones Fat57 customs ..... Also build a 54 fod COE ramp bac[​IMG]k photo soon
  16. Locomotive Breath
    Locomotive Breath
    from Texas
    I picked this one up earlier today. Runs and drives, 327 Chevy/4 speed/2 speed rear.
  17. fat57
    fat57
    Looks great ,,
  18. 348tripower
    348tripower
    Here are two new pictures. The 65 Ford tail lights I got from enjenjo are started. I have a pair of 7 inch LED lights coming to adapt to these lenses. I have the dash started and changed the seats out to a pair with out head rests. My purchase a the Kazoo swap meet.
    Probably no progress this weekend. We are headed to Freeport, Illinois to pick up Reds 40 with new paint!
    [​IMG] :D
  19. Locomotive Breath
    Locomotive Breath
    from Texas
    I really like the lines on the little 5 window up front in this picture.
  20. kooscoe
    kooscoe
  21. Valpmopar
    Valpmopar
    This is a '41 Chevy COE Limo I worked on a couple of years ago,still unfinished,homemade ch***is,1 ton front,1-1/2 ton rear,454 mounted behind cab,34' long
  22. FinkTinner
    FinkTinner
    heres '49 gmc c.o.e project
  23. FinkTinner
    FinkTinner
  24. kooscoe
    kooscoe
    Wow that is somthing out of the ordinary. Love to see it don:).
  25. Pauly da mick
    Pauly da mick
  26. FinkTinner
    FinkTinner
    Just dont know what engine to put in my c.o.e. Thinking BIG BLOCK. What u think?
  27. ratster
    ratster
    that's one cool truck, is it photo chopped?
  28. ratster
    ratster
    this truck
  29. Baron
    Baron
    Yep.
  30. Easiest way to tell - check out the repeated bunches of flowers in the background . . .
    Steve
