Picked up my Hemi today but prob with numbers
Discussion in 'The Hokey Ass Message Board' started by modracer, Mar 3, 2009.
  1. modracer
    modracer
    from georgia
    I picked up my Desoto hemi earlier tonight but cant seem to track the casting numbers down. Did a search on here and some other sites but the block number doesnt seem to come up.
    I cant make out the stamped number but the casting number appears to be 132742 and maybe a 5? It came with a 2bbl intake and carb and is suppose to be a 56 330. Any idea what it really is? It's loaded in pieces in the back of the truck right now so it wil prob be the weekend before I get it dug out if more numbers are needed. Also still waiting on the crankshaft as he couldnt put his hands on it just then so we'll see.
    I also got a big cast iron bellhousing , flywheel, clutch and a dual point distributor with it that he said he had pulled from a truck many years ago at a junk yard. Can the bellhousing be adapted to a Ford Toploader 4 speed or is it a paperweight?
  2. silent rick
    silent rick
    paperweight? more like a boat anchor
  3. modracer
    modracer
    from georgia
    Yeah my buddy went to pick it up and then decided to holler for the hand trucks.
  4. silent rick
    silent rick
    sure the 5 isn't a 9?
    1327429 is a 276
    wilcap sells an adapter to run a ford toploader behind your hemi, but it doesn't require using that heavy cast iron bellhousing
  5. modracer
    modracer
    from georgia
    It might be a 9. It has several layers of paint and crud on it so going to clean it up this weekend and se if I can get a better look at it. thanks.
  6. modracer
    modracer
    from georgia
    If it turns out to be a 276 is it worth spending all the money to rebuild it or should I look for one of the larger cubic inch ones to use?
  7. Dirtynails
    Dirtynails
    from garage
    It will cost the same to rebuild or hot up, it's your call but I would do it anyway,a 276 Hemi has more cred than a SBC in any size.
  8. Lucky667
    Lucky667
    from TX
    About the paper weight, do a search here. I read a thread that the truck b/h was somehow used to adapt a modern trans. About the casting #'s,..1332742? is a 276. The 291 casting # starts with 1558,..the 330 starts with 1636,...the 341 starts with 1856. The only other odd # is 1328829 and that is a 241 Dodge/Ply/DeSoto poly block #.
    I hope this helps. Good Luck.
    Lucky667
