Hot Rods Lokar shifters
Discussion in 'The Hokey Ass Message Board' started by hotrod_guy, Mar 6, 2009.
  1. hotrod_guy
    hotrod_guy
    from CA
    Is there a kit to repair a Lokar shifter that will not lock into park?
  2. texasred
    texasred
    from Houston
    YEA it's called a ginnie
  3. phat rat
    phat rat
    Should just be an adjustment. Why isn't it locking? ****on sticking or something else?
  4. Oldmanolds
    Oldmanolds
    Give Lokar a call. As much as they charge they should have a great tech line.
  5. stillkruzn
    stillkruzn
    from Conway, AR
    + 1
  6. hotrod_guy
    hotrod_guy
    from CA
    Im not sure the ****on will push in but is real slow coming out, you can grab the handle and pull it straight back into gear. I cant see into the tunnel through the boot enough to know whats exactly going on.
  7. 42hotrod
    42hotrod
    from S.E. Idaho
    Just a kind of random FYI, B&M offers a streetrod (dirty word, I know) shifter that has a nice solid chrome handle, just change out the knob to something a whole lot less billet and its a decent looking shifter. I used a typical hurst 4 speed boot on it and I love it. Heres a pic, but it still has that lame knob on it here...
  8. hotrod_guy
    hotrod_guy
    from CA
    looks good, would like mine to work.
  9. sawbuck
    sawbuck
    from 06492 ct
    hey hot rod guy.maybe you should take the boot off and have a look see ... then go from there..
  10. fab32
    fab32
    More correctly it's called a Gennie. Ginnie is a drunk broad that hangs out at the corner bar.:rolleyes::eek::D
    Frank
  11. hotrod_guy
    hotrod_guy
    from CA
    I have take the boot off. I can see anything further, I guess next step drop the trans?
  12. cruzr
    cruzr
    I had a Lokar in my coupe, i took it out and made a frizbee outa it straight into the trash can........now i have a Gennie Shifter........mucho better!!!!!!!!!!!!!!
  13. hotrod_guy
    hotrod_guy
    from CA
    If I can't fix this one, that's where it will be heading.
  14. 66Newport
    66Newport
  15. Von Rigg Fink
    Von Rigg Fink
    from Garage
    wow ..everytime i see this about the lokar shifters i wonder if i just got 3 good ones.. Or if its because the ones i read about on here not working correctly, is because they are not set up right? Or if the directions for installation were followed to the T?
    I know once installed I had to adjust them per the directions..but after that, and plenty of completely satisfied miles..absolutly no problems..and not just one install..3 I have done on 3 seperate vehicles.
    what Trans? what style..trans mounted? or tunnel Mounted?
    just curious...
    did you read and understand the directions ..? completely?
    I can pull down on mine when it is in park..and running and if i dont depress the ****on..it will not come out of park..you might also need to check your linkage adjustment..it might not be adjusted correctly..dont be too quick to blame the shifter.
  16. Von Rigg Fink
    Von Rigg Fink
    from Garage
  17. HOTRODPRIMER
    HOTRODPRIMER
    I've never had a problem with the one in my truck,,,
    try the tech line,,HRP
    tech@lokar.com
  18. hotrod_guy
    hotrod_guy
    from CA
    It is a c4, frame mounted if that answers your question
  19. hotrod_guy
    hotrod_guy
    from CA
    I do not have the instructions for the shifter.
  20. Have ya tried oiling it up? mine was doing that and oiled it up and no more problem.
  21. Von Rigg Fink
    Von Rigg Fink
    from Garage
    C4's were known to have issues with this problem even with the OEM shifters on them..and to add a (possibly ) poorly adjusted aftermarket shifter on it..could exasterbate the problem..or mask an unknown issue..I wouldnt be quick to blame the shifter knowing the C4's drop out of park history until you know for sure its not the trans..than it could be as easy as getting the Locar adjusted correctly and bingo problem solved..
    My experiance with Lockars is on 700r4's and Th350's..so far im batting 100%
    I plan on buying the swan , or S type 30" or longer for my A..
  22. hotrod_guy
    hotrod_guy
    from CA
    Did you remove the cable and lube or spray lube down the inside of the lever?
  23. chopt49
    chopt49
    I have install sheet for the Lokar Nostalgic 24" auto shifter. I can scan and send if you would like????
    PM me.
  24. hotrod_guy
    hotrod_guy
    from CA
    Awesome, I wanted to keep the "Ford in a Ford" but I know what you mean about the chev's.
  25. Von Rigg Fink
    Von Rigg Fink
    from Garage
    oh yeah i wouldnt be quick to discount the abilities of the C4..its a good trans..it had some issues as most do..im sure it can be fixed..(if that turns out to be your problem ..or the source of the park to reverse drop issue)
    I would look into that first before even trying to mask it with shifter adjustments..just so you are positive you dont have that issue.
    than move on to the shifter adjustments per installation directions.
    there might be a kit for that C4 to keep it from mis-behaving too
  26. hotrod_guy
    hotrod_guy
    from CA
    Any idea who would have the kit? Or should I just take it to a trans shop and have them look at it?
  27. Von Rigg Fink
    Von Rigg Fink
    from Garage
    I couldnt tell you..not a big ford guy..but if your not into trans work..I would suggest you take it to someone who knows the C4 and how to work on them.
    im sure they could get you on the right track...i would ask the guy how many hes done and if he knows how to deal with that quirk..
    and just in case it is your shifter and not the trans..you will know with out second guessing the safety of putting your car in park , and finding it where you put it last, when you come back out to get in it..if you know what i mean?
    especially if it was left running in park ..like while you open up the garage door..and turn around to see it flying across your neighbors lawn into their front porch!:eek:
  28. paintcan54
    paintcan54
    I had a Jokar ****er, took it out and put in a B&M I had on the shelf left over from the '70s works good, looks better too.
  29. LastMinuteMark
    LastMinuteMark
    from So. Cal.
    mine was sticky too, i took the knob off and took it apart, i put anti-sieze on the teflon bushing for the ****on, put it back together and it works perfect.......
  30. hotrod_guy
    hotrod_guy
    from CA
    Love your personal quote. The wife comes to mind,
    as far a s the shifter, Ill give it a try
