What engine should go into a 51 Ford F1
Discussion in 'The Hokey Ass Message Board' started by FunkyChicken, Aug 4, 2008.
  1. bizcoupeguy
    bizcoupeguy
    since they are merely all opinions, and i am a bit partial to my own, and lastly nobody has mentioned it yet.....
    390 FE.............do it
  2. floored
    floored
    Whatever you like, whatever you can afford, whatever you have laying around, but I do like the big block ford idea.
  3. P-townkustoms
    P-townkustoms
    from P-Town CA
    Whatever you do please don't use a SBC!!!! So many better engines than that! Lincoln 368 312 ford y-block 390 cad ,,,ect....
  4. art.resi
    art.resi
    Had a 364 nailhead in my 50 with a t 10 4 speed.
    Fun for sure.
  5. mtflat
    mtflat
    Canada didn't use the 6 cylinder engine. You would have had the 239 V8 originally.
    Does the truck have a column shifter or was it a floor shift? Several different transmission possibilities.
  6. FunkyChicken
    FunkyChicken
    I am pretty sure its a column shifter, there's no hole in the floor to suggest that its a floor shifter, this is the picture of the steering column. I do believe that you can see what I think is the side shifter
  7. bushwacker 57
    bushwacker 57
    My 51 f1 has a 53 331 cad stock column shift trans and 44 ****er rear i installed 331 ring and pinion . the cost to do the flathead was more. mike.
  8. 2manyprojects
    2manyprojects
    I got a 351C - FMX Trans - Nar. 9 inch rear. Smokes them 33" wide Mickeys They all be pushin my 51 F1 Panel.:D Usally only sneak it out on wifes gone:mad:
  9. RADDONKEY
    RADDONKEY
  10. Hubbcat
    Hubbcat
    from Sweden
    Arustupid???????????
  11. f1rave
    f1rave
    from alabama
    look at the motor mounts if they are on the side (right-left) side of frame V-8 if you have the to holes up front at bottom of radiator L6
  12. f1rave
    f1rave
    from alabama
    I have a 215ci L6 and a 3 speed out of a 51 f1 for sell if you like let me know
  13. 57Custom300
    57Custom300
    from Arizona
    I'm with P-Townkustoms on this one. I think I'll punk if I see another sbc in one of these. I'll add sbf to this also. If you don't go with a flathead (my 1st choice) do something different. Old Chrysler hemi, Nailhead, 409 or Y-Block. But it's your truck, put what you want in it.
  14. HOT40ROD
    HOT40ROD
    from Easton, Pa
    Check for a small tag on the uper right side of the fire wall. and also check the bulk head of the cawl under the hood. Some times the numbers is stamped on it. It could be covered with filler if some had redone the truck
    Also it the radiator support is still in it check to see with set of holes it is bolt to on the frame cross member and the inner fenders. If its bolt to the rear holes it was a v8 if the front holes its a I6
  15. Theo:HotRodGod
    Theo:HotRodGod
  16. redshoes36
    redshoes36
    no cheezy corporate wellfare gm products. A 87-93 mustang 302 rollermotor with the t5 trany you can put a long shifter handle on it. Also you will get good performance and milage. IT will be a blast to drjve.
  17. PhilJohnson
    PhilJohnson
    I would have hoped the guy has figured out what came in there in the last two years since he has posted. I never can figure out why people will unearth an old thread and post an answer to a question that was asked years ago :confused:
  18. teddyp
    teddyp
    show some balls put a sbc in it and piss the cry babies off really this is a hot rod site put what you want in it and have fun with it
  19. Mildsteel
    Mildsteel
    from VALE N.C.
  20. iwanaflattie
    iwanaflattie
    Im reviving this thread to post a question for a feller f1 owner.
    <hr style="color:#D1D1E1; background-color:#D1D1E1" size="1"> i have a 350 witha 4 speed Muncie in my f1..But my clutch linkage is all messed up ..i guess someone fabricated it, i just cant seem to get enough throw out of it..and when i do i loose the freeplay. so if you have any suggestions or know some who has done this i would really appreciate it...cuz this is killing me!!!
    Any help would be great
