Projects winter project - "so let's chop a 40 coupe (and fab everything else possible...)
Discussion in 'The Hokey Ass Message Board' started by zibo, Feb 16, 2009.
  1. Travis, you're in the "ZONE". Really coming along nice!
  2. R.Allan
    R.Allan
    from Ca
    thats *****in!
  3. Man stamping your own replacment parts, and making your own belhousing ? Thats over the top! Nice work!
  4. Bill H.
    Bill H.
    GGGGGS.
    Looks good! Whats next? If you keep moving the engine back, might have to sit in the back seat.
    Keep going.
    BH
  5. zman
    zman
    from Garner, NC
    dude you are like Shaft... one bad mother... inspirational work on something that most of us would overlook.... thanks for keeping us up to date.
  6. koolkemp
    koolkemp
    Hope theres more updates comin!! This is one of my top fav threads of all time on the HAMB
  7. James D
    James D
    Great build up. Must be kind of liberating to start with so little - you can pretty much build it just how you want, and not have to worry about ruining anything or cutting stuff about.
    falcongeorge likes this.
  8. carlos
    carlos
    from ohio
    YOu da Man ,Looks good
  9. zibo
    zibo
    from dago ca
    Hey guys.
    Haven't had time to post here so here are some updates...
    First kinda mounted the rearend.
    cut and rejoined the front '36 radius rods.
    started on a double torque arm.
    Gonna sandwich triple rubber bushings up front,
    (still missing the top bracketo)
    TP
  10. zibo
    zibo
    from dago ca
    Found the exhaust at the big 3, so decided to start that up.
    Very time consuming project!
    First had to make flanges...
    Also decided to use black-pipe elbows instead of those sheetmetal ones.
    first tubes mocked up...
    Funny cause the between these pics,
    the whole firewall was cut out and rewelded,
    it was a little skewed after squaring up the rear area.
    Of course it was after the fenders and exhaust were installed!
    TP
  11. zibo
    zibo
    from dago ca
    The center port is larger , so used some s****..
    The tricky thing is the flange aren't bolt-ons like most engines.
    Like alot of early GM's,
    they use a tall stud with T-clamps.
    So a little triangle is welded on as the T-clamp base.
    TP
  12. 60'shotrod
    60'shotrod
    Zibo, You Sir are one skilled craftsman and have Vision by the bucket load.
    That is gonna be one tuff lookin' '40, I'm lookin' forward to the next in stallment.I personally think that '40 Fords are one of the BEST lookin' cars ever built.
    I love the look of that Cadi' Flathead, they very unusual lookin'.
    Nick.
  13. GEBHARD
    GEBHARD
    from TX...
    i like the header placement looks good
  14. Hot Rod Michelle
    Hot Rod Michelle
    You can get the Detroit Diesel Green at your local truck parts supplier, or any place that sells and/or services cl*** 8 heavy trucks.
  15. zibo
    zibo
    from dago ca
    half done!
    alot easier to pre-grind without the center tube.
    no "sellers quality" work here...
    The angle is a little off on the front, so need to cut and reposition at the blue lines there.
    TP
  16. hotrodjeep
    hotrodjeep
    Those are some damn ***y headers.
    Bad*** Elegance
  17. captainjunk#2
    captainjunk#2
    man this build is Bad*** you do some great garage fabrication ,
  18. 38FLATTIE
    38FLATTIE
    from Colorado
    Travis, this car rocks! I really liked your bellhousing thread, but this coupe is sweet. Love your engine choice, and those are awefully sweet headers. Keep up the good work!
  19. zibo
    zibo
    from dago ca
    thanks guys!
    38flattie-I would love a front mounted blower on this thing...(and one of your cams!)
    TP
  20. 38FLATTIE
    38FLATTIE
    from Colorado
    lol! I've got one more hydraulic , and one more solid one on the way. I'm working on a tri-power, but after seeing your work, I should wait until you tackle it!
  21. mazdaslam
    mazdaslam
    WOW !!!! Very cool. I love these types of builds,they show an amazing ammount of creativity.
  22. Pretty friggin FABulicious:D. I am inspired!!!
  23. back to work dooder. I have trouble finding my rhythmic breathing pattern when falling asleep if there ain't the dead, and grinding past 11. And no body want's a cranky shop dwelling caveman, or troll. I like troll better. Yes, shop inhabiting attic troll. Indeed.
  24. junk fiend
    junk fiend
    the HAMB needs a "i not worthy" smile. i thought you were going to use that body as practice for your other 40 and not build a whole other car out of it:eek: looks awsome!
  25. OL 55
    OL 55
    Godam Zibo!! That's incredible. I don't know how I missed this thread! Can't wait to see it done.
  26. joel torres
    joel torres
    wow after seeing this i have to go outside and weld my floors in this build is inspiring
  27. zibo
    zibo
    from dago ca
    These headers took a long time.
    Actually it was probably only 3 good days work spread out over a month of afterwork nights,
    and I thought I was keeping the "attic troll" up!
    signs of the attic troll...
    These changed the build process alot,
    instead of just bolting flanges on like most engines...
    1-the 90 is tacked on, hopefully positioned toward the collector-pipe
    2-the T is cut and stepped, hopefully there's enough gap between the 90 and the stud
    3-then a little triangle is welded on to the 90, and hopefully it cinches down correctly.
    4-then the typical header fitting can be done.
    5- even though there's 6 pipes, its (x8) since the center hole is widened, and has 2 T's...
    I really want to finish them off better and either nickel, chrome or ceramic-coat them.
    Thanks for the posts guys!
    now on to the door hinges...
    TP
  28. flynbrian48
    flynbrian48
    Oh. My. God. Unbelievable. You started with something that NOBODY would haver even considered remotely buildable, it's amazing. I thought my '36 was bad to begin with, and turned out pretty well, but this makes me want to start over. Great, great job.
    Brian
  29. 4rod
    4rod
    Very cool Build, actually delightful..."NO WASTE," brother keep it up!
  30. Casey
    Casey
    nice work .
