Projects New Bonneville Car
Discussion in 'The Hokey Ass Message Board' started by DETMER METALSHAPING, Mar 10, 2009.
  1. DETMER METALSHAPING
    DETMER METALSHAPING
    Here are some pics of a new bonneville car we are skinning. Should be done in 2 weeks. Plans are to shake it down at Maxton in June then turn it around for Bonneville Speedweek in August.
  2. HotRodFreak
    HotRodFreak
    Good Luck with the racemobile.
    I suggest that you read the book carefully in order to p*** tech without issues..
    Which cl*** or cl***es are you going for?
  3. Chaz
    Chaz
    Very nice metalwork! Looks like it'll be in the lakester cl***es?
  4. Speedwagen
    Speedwagen
    Looks like a rear engine modified roadster.--lookin' Good !
    It's a good plan to do Maxton first. It will make tech inspection at Bonneville a little smoother if they see some Maxton action in the log book. Make sure the body meets original dimensions!
  5. HOT ROD DAVE
    HOT ROD DAVE
    hay is the book posted on the web?????
    if so do you have a addy????
  6. Speedwagen
    Speedwagen
    Check the SCTA or the USFRA web sites to order a rule book
  7. slepe67
    slepe67
    nice work. How about a HOW-TO on, um, how-to build the aluminum tonneau for us poor folk!
  8. 28rpu
    28rpu
    Nice job. Too bad you didn't lay the driver down. Nick
  9. Beef Stew
    Beef Stew
    from So Cal
    looks good. don't forget the lateral head movement restriction.
  10. speedtool
    speedtool
    Keep us informed & good luck.
  11. Bad Bob
    Bad Bob
    from O.C. Baby
    That look SOOOOO cool! Hope to see it when it's done...
  12. DETMER METALSHAPING
    DETMER METALSHAPING
    Thanks for all the input on rules and stuff. We are in the fortunate position of only having to make the body. The guys who are building the car are the ones who have to worry about p***ing tech. We did get a body measurement sheet from scta to make sure we were staying legal on the body. It is a rear engine modified roadster. Don't know engine size yet but it will burn gasoline. The guy who is driving the car prefers to sit more upright and since he is paying the bills he is getting it the way he wants.
  13. Dean Lowe
    Dean Lowe
    Done in 2 weeks??!
  14. Dynoroom
    Dynoroom
    Is this the new car Vic is working on?
    Driver comfort is very important but you'd a thought he would recline a bit....
    Ours is ~45 degrees. He's very comfortable.
    It will have some type of hood scoop this year.
    Nice looking car you guys are building though. AA, A, or B?
  15. HotRodFreak
    HotRodFreak
    FYI you can still run fuel cl*** if using gas.
    Some fuel cl***es have a lower record to beat.
  16. Bluedscrewed&tattooed
    from AUSTIN,TX
  17. krusty40
    krusty40
    Hi Mike - He is at about 45*. Before we final welded the upper cage, I put the driver/owner in it and he decided to keep the cage as tall as it shows; he said " we can always lower it, can't we?" Yep. (Also, the customer is always right...) Engine is a de-stroked Hendrick SB2.2 for D Gas being built by Keith Dorton at Automotive Spe******ts. vic
  18. JeremyJames
    JeremyJames
    from concord NC
    damn that thing is looking sweet. im gonna have to come take a look at it up close
  19. RichFox
    RichFox
    I wish I had spelled "explain" right
  20. Bobby Green
    Bobby Green
    "Hey, .... You got your streamliner all over my roadster".... "No, You got your roadster all over my streamliner" ....... "Mmmmmmmm delicious"
  21. DETMER METALSHAPING
    DETMER METALSHAPING
    Body done. Months away from total car completion.
  22. HOT ROD DAVE
    HOT ROD DAVE
    those cars are lookiing good, makes me want more and more to go to the salts
  23. DETMER METALSHAPING
    DETMER METALSHAPING
    Very nice car. I'm out there every year with car#453. c/fuel roadster outta Texas. I took Vic out there with me a couple years ago and of course now he is hooked. Vic said big block so I wouls guess A cl***
  24. DETMER METALSHAPING
    DETMER METALSHAPING
    Owner wants a red hat which reqires at least a 225 mph record. The cl*** record is 187 mph I think he said.
  25. DETMER METALSHAPING
    DETMER METALSHAPING
    We were saying the same thing.
  26. DETMER METALSHAPING
    DETMER METALSHAPING
    I was wrong on motor size. The guy responsible for the build explains the motor deal in one of his posts above.
  27. Carbonkenny
    Carbonkenny
    red , very very nice.
    Carbon:D
  28. mtkawboy
    mtkawboy
    Wouldnt have been a bad idea to get the rule book first before building the car. Very nice work !
  29. Beef Stew
    Beef Stew
    from So Cal
    maybe you can elaborate how, by looking at these pictures, you've determined that they built the car without referring to the rule book?
  30. krusty40
    krusty40
    I'd be interested, too, as I've read that F%#@*&^ book a few hundred thousand times while making sure I'm doing things right. BTW, Kenny, what have you got in your lineup for a rear-engined dragster-type scoop? Iguess I'll have to come by the shop next week. vic
