Projects Wannabe tubester
Discussion in 'The Hokey Ass Message Board' started by akseli von gardan, Jan 15, 2009.
  1. Well , now it´s "ready" !
    Some minor things to do before longer trips but now it´s drivebly and have made it´s first miles... and smiles too! :D
  2. Janne
    Janne
    Great! We need some motion picture!
  3. Hillbilly Werewolf
    Hillbilly Werewolf
    wow. out of control bad***!
  4. MedicCustoms
    MedicCustoms
    Is their a hot water heater.... I think its cool but I'm a odd ball. I like the Tubster
  5. attitudor
    attitudor
    from Finland
    Looks wicked! How 'bout adding a "cowl" between the motor and steering wheel...?
  6. jusjunk
    jusjunk
    from Michigan
    Im wondering what happens when the chains come loose and smack you in the back of the ****ing head :).... Excedrin headache number ?
    Dave
  7. I tryed to fit cowl and dash from 34 ford junior , but it totally take away the tub-effect , and all the vital info is allready readable from enginebay... oilpressure is visible via pressuregauge that is top of the intakemanifold, generator has it´s own light so there is no need for dash anyway.
    And yes i´m affraid of those chains... i have somekind respect to those and keep the speed low.
    Motion picture is in progress :confused: i´m not so expert with these F%%¤n computers;)
  8. <embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://i3.photobucket.com/player.swf?file=http://vid3.photobucket.com/albums/y58/Akseli/Motion%20pictures/saransynttrit016.flv">
    Lets try if this works...
  9. lostn51
    lostn51
    from Tennessee
    I love the thing!!! The steering wheel rocks, the tubs rule, and its powered by a flathead, what more do you need? And he is driving it with chains on the tires in the snow and ice, this my friends is a die hard hot rodder!!!
  10. Yeap , seems to be working , here´s another short shot:
    <embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://i3.photobucket.com/player.swf?file=http://vid3.photobucket.com/albums/y58/Akseli/Motion pictures/saransynttrit018.flv">
    After this i´m off to Florida next few weeks , to warm up a little , see you in Billetproof at Garlits or Daytona spring show!!!!
  11. Bill H.
    Bill H.
    Sounds good, just would not want to stop too fast in the tubs. Might loose all the bath water.
    P*** the soap.
    BH
  12. racer67x
    racer67x
    thats great..lol
    at least you're having fun no matter what the neighbors think.
  13. SteadyT
    SteadyT
    Very creative. I like it.
  14. jusjunk
    jusjunk
    from Michigan
    Ok how long before the stickers wear off a tire when run on snow?
    Dave
  15. Janne
    Janne
    Thanks for the vids!
  16. phukinartie
    phukinartie
    Cleanliness is next to rodniless I always say!!
  17. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
    So rad. Weird as heck, but rad!
  18. Looks like a ****** commercial waiting to happen. :D
  19. Don´t know yet , i have made few miles on the snowy surface and those stickers just hang on.... Slippery when you brake if that thing is pointing down.
    Next time i´ll drive the tubester ,the snow is propably melted so stickers will fly ;)
    I had to check what the hell is ****** commercial , but now i know:D:D
  20. Ok , back in cold Finland , i just moved tubester out of the way to have space
    so i can change new and bigger engine to Nash.... Summer is coming , FAST! :)
  21. wow, thats real cool. i cant wait to see how it turns out.
  22. I wasnt realy feeling this untill I saw the drive by video, that thing is so ****ing cool!
  23. Thank for the link , have to try it someday , for now i´w painted the badly rusted bottom of the driver´s side tub with epoxy-gray. At least it will keep my jeans clean from rust... at least from outside :D
  24. Ok , i just took off the chains ,no more snow here :D
    I drove a couple miles with that thing and engine stumbled , it seems to be having too rich fuel/air mix?
    I worked few hours to figure out what went wrong , it seemed to shut down allmost all sparkplugs , they only give sparks at iddle , but wont fire under the load. I put new fuel in the tank and drain the carbs and so on , chek the distributor (new msd billet) ewerything was ok.
    The little ****** 60hv flatty has two ford 94 carb (on eddie mayer intake) , both with 55 powervalve and number 50 primary jets.... Has anybody deal with this combination , should i go with smaller jets or just plug the powervalves off:confused: I allready order some smaller pw´s ,35 and 25 if they work better? I think that small engine is not capable to make enough vacuum to keep those pw´s shut when you throttle it just a littlebit?
    Those carbs allso would need a proper fuel-level valves , original ones don´t have rubber tips and they are tend to overflow regulary...
    If someone have basic tuneup tips for this combo , it would be nice to hear . so i don´t have to make all the mistakes :)
    Thanks . AVG
  25. Nobody played around with 60 flatty and two 94?
  26. Casey
    Casey
    That`s crazy I like it !
    on my big flathead I run 3.5 power valves .50 jets and 2 pounds of pressure
    with a 2 carb set up
  27. I do have that pressurising allso in mind ,but with 51 lincoln BIG flatty....and a different car.
    This small succer needs to be adjusted so i can take a few trips with it in this summer.
    Well, i try this and that ,when i got those different size powervalves and jets.
  28. Casey
    Casey
    my motor is a 51 merc wasn`t thinking about the bigger lincoln
    my 32 coupe ran rich as hell until I took the 7.0 pv out and cut them in half to 3.5`s
    talk to ****ster27 on here he could probably tell ya what they need
    www.****shotrodplace.com
  29. Thanks , i try to contact him. I usually try everything else my self before i ask ,but now i´m trying the other way.. :rolleyes:
  30. Ok , now it´s working better , i put 2.5 pv´s to carbs and it helped a lot , and car have made it´s first longer trip (a hefty 30 miles :D)...
    Seems to be in the rich side still , so next i try those smaller jets ,let´s see what happen.
    The engine has been overhauled about 20 years ago , i just take a peek inside before bolting those go-fast-goodies on and it seems that valve closing is based on bouncing from the aluminium head :eek: (or it sounds like it :p)
    I´ll have to figure out where i could find new valve springs for that engine.... some newer car perhapse?
    AVG
