Here are a few shots of the "******* Bucket." Still have a long way to go, but pretty excited. The body needs alot of TLC, I will be running a Chevy 250 inline six. I know i'm going to catch hell for the suicide front end sorry for the bad pics there off a phone. I want to thank az/willis for doing an awsome job on the ch***is!!
looks good man. justed started my first rod to. its alot harder than i thought it was gonna be for shure
Pick up the ch***is yesterday after the drags, rough mock-up this morning. Here are some better pics. My pants are getting tighter!
I gotta say is this the hamb I'm reading. Looks good ****!!!!! I got grilled roasted flipped hot sauced and served up on a plate after posting pics of a suicide front end not six man I wanna kiss your *** comments Just bringing it back !
We believe its a 1927 Dodge touring body. It has been molested though.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Model-a-fan here is how I mounted the perches to the bones. I used speedway perches and made a spacer so I could tighten them down until the front end is set then I will weld them in place to clean it up. The springs I used are stock model A's that I had a local spring shop shorten two inches. Also used stock crossmember so I could save my horns, but with that big *** lincoln installed I may have to C-notch the horns. I tried to save some money and instead of buying flat top perches from speedway, I made my own out of grade 8 tapered machine bolts. Saved 10 Bucks if you don't count my machine time.
let me know when you need more done gunk and ya it is my coupe in front of gunk's ride if anyone need some work done in the phoenix area pm me or e-mail me at twistedfabs@hotmail.com
