who handles vintage NUTS?
Discussion in 'The Hokey Ass Message Board' started by Tuck, Oct 28, 2008.
  1. hotrodladycrusr
    hotrodladycrusr
    I wouldn't call the nuts I handle vintage....alittle on the older side maybe, but not vintage.:D
  2. Thanks Tuck.
    Depending on how much you have to turn off, you may be able to do what you want with a thick Centerline style washer.
    They're 3/16" thick and the 'hot' setup for the oval drilled mags that don't have to have an adapter.
    Depending on what you need in the washer dept., you can make your own out of stainless round stock on the lathe fairly easy.
    You should burn up about 2-3 hours for 20 of them.
  3. jonnycola
    jonnycola
    Wow, thats gross.
  4. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    this is what that guy wrote me back C9... regarding those 8002's I pointed out...
  5. HOTRODDORK
    HOTRODDORK
    from Michigan
    Old squirrels? Sorry I couldn't help it.
  6. Abomination
    Abomination
    Beat me to it, man. That dude seriously rocks.
    ~Jason
  7. jonnycola
    jonnycola
    Damn, that's still gross.
  8. i'm going to need the throated kind that extend thru the mag....question is how tightly should the extended part be in the mag hole???looked at parts store last nite, they either went thru too far or wouldn't go thru the mag being too fat of a lug..lug nut king has tons of info, but how tight thru the hole should the lug be??
  9. Goldrush Gasser
    Goldrush Gasser
    from norfolk uk
    Catherine zeta jones
  10. Still no answer on the "spinning blade" lug nuts... are they a type of locking lug nut?
    Oh, and the late Anna Nicole Smith, and Elton John's boyfriend.
  11. Would Vintage Nuts be the same as Old-Man-Balls ?? >>>>.
  12. turbojoe
    turbojoe
    from Detroit
    A vintage ******?
  13. pan-dragger
    pan-dragger
    that shank will not be a problem, but finding lugs with that head design now a days will be super hard.
