olds boat intake??? will work on car??
Discussion in 'The Hokey Ass Message Board' started by 4bangerNick, Mar 20, 2009.
  1. 4bangerNick
    4bangerNick
    Hey guys - yone run a boat intake on their car or know if I'd run into any real problems running a old boat intake ( 4 strombergs ) in a car motor other than adding choke to carburation? lacking heat riser????? anyway to byp***?? thanks !
  2. Hip
    Hip
    I little more info please.
  3. 302GMC
    302GMC
    from Idaho
    Some of them mount the carbs backwards & at a steep angle ... they don't work well on a car.
  4. Belchfire8
    Belchfire8
    Had a friend back in the day with a '65 Pontiac Lemans 326 two barrel. He wanted a four barrel on it and got a "good deal" on one from a boat. he drove it about one mile after install, the carb was tipped at such an angle that it flooded out from the moment you hit the key!!!
  5. lango
    lango
    from Georgia
    Maybe if you make a "G***er" outta it...
  6. Post a pic most of the ones I have seen will work.
  7. as 302gmc and belchfire8 have suggested, it may or may not work....you better post some pictures. i used to be partners on a 1967 Lewis boat with a 327 chevy and it had a screwy intake
  8. As noted, some boat intake manifolds have the carb bases cast at an angle and others use an angle adapter.
    If the angle is cast in, there may be enough material to mill the intake flat or you could make some angle carb adapters to get the carbs to level on your engine.
  9. 4bangerNick
    4bangerNick
    they look pretty flat to me.....i wash shock it was outta a boat except no ****erflies/choke.
  10. 4bangerNick
    4bangerNick
  11. 4bangerNick
    4bangerNick
  12. 4bangerNick
    4bangerNick
  13. 6deucecaddy
    6deucecaddy
    Got any bigger picks? Kinda looks like and old HORNE intake!
  14. 302GMC
    302GMC
    from Idaho
    That should work fine, looks like a cold "compe***ion" style manifold for a race car that ended up on a boat.
  15. Paul
    Paul
    Editor
    hard to see in the tiny picture, could be CRAGAR
  16. 4bangerNick
    4bangerNick
    is a cragar!!!!
  17. choppintops
    choppintops
    It will work fine.
