Foam in my Plymouth rockers
Discussion in 'The Hokey Ass Message Board' started by My49Plymouth, Mar 21, 2009.
  1. My49Plymouth
    My49Plymouth
    Question guys:
    I am starting to remove the rot on my 49 Plymouth. The rockers / sills are filled with foam (polyurethane?). Was this a factory thing or done durign a "repair"? Is it good or bad and should I refill it with foam when I fix it?
    thanks for any input!
  2. jusjunk
    jusjunk
    from Michigan
    Your kidding right :)... Maybe someone was trying to duplicate the Amphicar (spelling)
    I dont know why anyone would do that but no its not factory
  3. Frankie47
    Frankie47
    from omaha ne.
    It didn't come from the factory that way, they hadn't even invented expanded foam yet. Someone just used it for a filler so their bondo would stay in place.
  4. tommy
    tommy
    That's a modern repair. The traditional repair was to use wadded up news papers.:D
    Someone used the spray can home insulation to fill the void so that they could smear the bondo on top.
    Do a proper repair with replacement rockers welded in place leaving drain holes like the factory did.
  5. chopo
    chopo
    DANGER DANGER>>>>> **** is very flameable> trust me dont ask how I know:rolleyes: watch out how you remove it.
  6. junkyardjeff
    junkyardjeff
    I have some replacement rockers for a 49 to 54 chrysler if you think they will work.
  7. foam will trap moisture and cause even more problems
  8. dubbie
    dubbie
    sorry for the luck there. Its interesting the things you find in these old cars used to "fix" rust. I have found up to 3/4'' of bondo in my 50...along with screen, cardboard, foam, and fibergl*** mat. Like everyone will tell you, cut it out, buy or make a steel patch panel and get it fixed right.
  9. SlowandLow63
    SlowandLow63
    from Central NJ
    Oooof. Someone got over on you. Did you just buy the car recently?
