Hey ya'll, I'm driving the Crestliner to Jackson, TN in mid-April for the Bunny Run and since I am still not sure that I have a good grip on the cooling issue- I'm thinking of adding 'water wetter' (or something like it) to the system. Questions: Have any of you used stuff like this?? What was it? and Did it seem to help the motor run cooler?
I've used it before. I was trying to cool down my T. It brought the temp down by about 10-15 degrees.........then the radiator puked. I'm guessing it's worked. Looked like some type of glycerine product.
I've used it in a roadrace race car that ran warm and it did lower the temp maybe 7-10 degrees but it is no subs***ute for a bad cooling system
I use it in my nostalgic drag car due to a small rad, however; it is not a fix. The water wetter will lower your temp slightly......
I have to agree with this. A buddy of ours had some cooling issues going on (due to bad fan relay). It brought the temp down a bit, but I don't think I'd want to make a habit of using the stuff instead of sorting out the cooling system.
Used it on a nascar type race car every week.It works.A few degrees.If you expect alot it wont happen.
Water wetter does work. Photographers use it when developing film....it lets the film dry without water spots on the negative. It is also in dishwasher soap.......keeps the water spots off your gl***es, etc. It simply reduces the surface tension of the water, so it will flow a little better. Doesn't hurt a thing to run it all the time.
Thanks for the replies...I know it isn't a permanent fix (probably the only 'real' one will be a thicker radiator - with more cooling capacity) but I'd like to use everything I can during our trip.
I've been using it for years in all sorts of my vehicles...like stated above helps a little but is no subs***ute for a proper functioning cooling system. Hope your trip is uneventful....
I run the Redline stuff in my roadster on the street. It runs 5 to 10 degrees cooler. As already said, it helps, but is not a fix for an inadequate cooling system.
It's a better corrosion inhibitor than temp displacer. We ran it on the round track cars because the rules would not allow anti-freeze on the track.
Exactly why I use it as well. In a race car where use of Ethylene Glycol is not permitted. No idea on how much it knocks it down, just know its better than straight water.
or theres that Evan's NPG stuff out there..... I havent used it but I know people that do and wont switch back nor have any complaints.. boils at like 400* instad of 212* oh yeah one complaint the price
Ive used it, and its helped, but as already stated it isnt a miracle, all it does is break the surface tension of water so it actually gets more surface contact with the cooling system, just increases efficency.
I used it in my '54 Buick down in Floriduh, and was very happy with it. But, as others have said, it's a great addition, but not a cure-all or even a fix. What's your combination? If you've got a 4-blade fan, upgrade right away to a 5 or 7 blade fan. Get the biggest diameter fan you can find. Muscle car restoration companies are a great source for big diameter, 7-blade fans: you probably won't find one in the junk yards that don't have a clutch, and if you do, chances are good the blades will be bent. I bought three different junk yard fans before spending the bucks on a new one. I also like a thermostat that opens sooner in the summer: 160-degree versus a 180-degree. My theory is that the radiator doesn't have to play catch-up once you're stuck in traffic or something. And of course, a shroud. But it sounds like you haven't gotten to that point yet. (I didn't on the Buick). Bigger diameter fan with more blades, cooler thermostat and water wetter will be a good step in the right direction. And if you're a little shaky about spending that much on a repro 7-blade fan (the resto companies are VERY proud of them), think about how much it's worth NOT to be sitting on the side of the road overheating, or worse, blowing a head gasket. -Brad
I have it in my sbc powered 31 and it brought the temp down about 10 or 12 degrees. Seems to work good.
If the weather in Jackson is like it usually is, it will only be about 40 degrees. See you there and bring a big coat.
Use it as a routine. Just like putting all 8 plugs in a v8 and all 4 tires on my cars. Why would you NOT use it. There is an old saying, "every little bit helps". Frank
Man if that stuff will lower my temp by 10 degrees I'll give it a shot! Wonder what it costs locally, it's about $15 shipped on the 'bay
You can use Dawn dishing washing soap and it does the same thing and a lot cheaper, that's how soap works , it breaks the surface tension therefore making the water wetter "Doc" Parsons
If you really think you need it........... ...........it just reduces the surface tension of the water. A few drops of dishwashing liquid will do the same thing.
When does your car overheat?? Basically two reasons, poor air flow, or poor fluid flow. Usually air related in traffic, and fluid related at highway speed. Everybody uses 50 50 antifreeze for the same reason that everybody changes their oil every three thousand miles. Anti freeze does not have the cooling capacity of water, it aborbs less heat and releases it less effecively than water. So one of the easiest things you can do is reduce the amount of antifreeze you put in your mix. I don;t drive my car in the witer, so I use a 80/20 mix. I run a flat head 6 and it nevers runs above 190 even sitting at Canada US customs in 90 degree weather for about 45 minutes. Running dow the road it barely ever gets above 160/170. You don't mention what condition your system is or if its capacity has benn altered from stock, nor do you say whether your fan is as engineered or modified. I had a budy compain about overheating after changing to an electric fan, finally found out had the blades on backwards, so he was blowing against the wind so to speak. But for my money, a bit of water wetter, less antifreeze, in Tn you probably need enough for anti rust and water pump lube. and give it a shot.
It works pretty good, about the same as the Royal Purple product (most NAPA stores and a lot of Toyota parts departments have the Royal Purple stuff). I think Water Wetter and the Royal Purple stuff are the same thing. The amount of cooling improves if you run less, or no, coolant. The bottle shows the ratio. If I remember correctly, the Royal Purple one claims something modest like 5 degrees with a 50/50 mix and 15-20 degrees with straight water. I've noticed maybe a 5-10 degree difference running about 25-30% coolant, which is fine since it's something you only add when you flush and fill. Like other have said, it's not a subs***ute for a ****py cooling system. My 223 ran hotter than hell and this stuff didn't help. My SBF runs pretty cool and this helps it a bit.
