need help identifing
Discussion in 'The Hokey Ass Message Board' started by BMR, Mar 25, 2009.
  1. BMR
    BMR
    from ill.
    having some brake issues with the rearend. whats the best way to figure out what the rearend is out of?
  2. HR Classic Cars
    HR Classic Cars
    from Wylie, TX
    Post some pictures, of the center pumpkin (front and back), the tubes, the backing plates and the brakes.
    Also measure the width (mounting surface to mounting surface) and the drum diameter, all that info helps.
    Someone on here will be able to ID it.
  3. post some pictures.....any tags on it?
  4. Little Wing
    Little Wing
    from Northeast
    :confused: well is it chevy ford dodge ?? once you know that ,,pull the drum and you should know what your dealing with..with the info your giving,,kinda like peeing on a flat rock in the middle of a thunderstorm
  5. BMR
    BMR
    from ill.
    I know its a GM. i tried to use casting #s off wheel cylinders but nobody could do it. Is there any other place to look for #s.
  6. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Okay......does it have a removeable rear inspection cover, and if so, how many bolts hold it on? Without pictures, this may take a while.
  7. BMR
    BMR
    from ill.
    the adjuster hole is in the drum. ill try to figure out how to do pics
  8. choppintops
    choppintops
    Just post pics.
  9. BMR
    BMR
    from ill.
    pics??
      111.4 KB
      108.4 KB
      109 KB
      107.7 KB
      113.7 KB
  10. Nova or Camaro because of pinion yoke. Is the bolt pattern 5 on 4 3/4"? Does it look like somebody torched some axle seats from under the housing about where the coil over shocks are located?
