whats your work truck?
Discussion in 'The Hokey Ass Message Board' started by chappys4life, Feb 23, 2009.
  1. 2manytoys
    2manytoys
    from Fresno
    (2) 94 F150s and a couple of my Divcos
  2. ma70tt
    ma70tt
    posted this truck earlier, dont think withe exhaust though...
  3. 296moon
    296moon
    from england
    Been useing the chevy for three years soon to be joined by the coe [​IMG] [​IMG]
  4. havi
    havi
    For $300, and 50,000 miles later without any problems until this last Fall when the AOD went, it has served as tow rig, parts hauler, and around-the-yard-tow-truck. (I have a separate back bumper with a cherry picker bolted on) I'll need to replace it this year :(
  5. Abomination
    Abomination
    Dude, I totally want to see that cheery picker bumper...
    ~Jason
  6. weldtoride
    weldtoride
    296 Moon, I do like your trucks, especially the COE. Post more pics as you go.
  7. havi
    havi
    Jason...Ya know, I don't have any pics of it. It's a 5"x5" 1/2" wall square tube with 1/2" plate 5" wide welded on the ends with holes drilled to bolt into the truck frame. Then 2 holes drilled through the center top and bottom, with long grade 8's and washers holding the picker. Then ratchet straps at the top going to the forward most pockets on the bed. Take about 10 minutes to bolt on with an impact. I use it to move engines around the yard, and my F1 without engine and trans once. Cheaper than buying a tractor, lol.
  8. mazdab2600
    mazdab2600
    work n play
    ok they both work.:D
    2005 canyon
    1991 mazda b2600.
    wife's 1999 caravan
  9. Abomination
    Abomination
    That's outstanding!
    Dude, you're my hero! :D
    ~Jason
  10. ksousa
    ksousa
    '57 gmc
  11. grits
    grits
    Dude, we should be neighbors,:D i wouldn't mind helping unload that thing. LOL
  12. Anderson
    Anderson
    Mine for the last couple years (and daily driver), might be replacing it soon.
  13. rayjon
    rayjon
    from Reno Nv..
    92 dodge reg cab 4x4 with a ***mins and a 5speed, pumped a little with a 4 inch staight pipe, 300k and still going...has the normal dodge rattles... but has no problem with a 15k lb trailer...
  14. manyolcars
    manyolcars
    working every day for 16 years so far, pulls heavy loads
  15. OGNC
    OGNC
    My "work" truck is a 2008 Tacoma, Total Chaos long-travel uni-ball front end, Deaver leafspring pack out back, King byp*** shocks all the way around... I toss stuff in the bed, it has been used to haul a trailer or two and it has served as my swapmeet hauler quite a few times already...
  16. Silent_Orchestra
    Silent_Orchestra
    from Omaha, NE
    Well I've got a '94 Chevy 1500 2wd Standard Cab long box, with a 425 Olds and a TH400 she'll get some small work truck duties when she's done..But for the heavy lifting it's the '03 Dodge 3500 4x4 6spd ***mins powered beast.
  17. Well, I picked up a cheap '91 Suburban to replace the '89. A little fancier - cloth interior with bucket seats, tilt, air, factory PW, power locks that work, looks like it even has antilock brakes by the looks of the master and the computer with it. Body's a lot nicer, and as a bonus the red and silver is a good match for Tony Stewart's Nascar paint scheme. And it's another TBI 350 with a 700R4. I figured if I needed parts I could rob them from the other one - and I'm already used to all the half***ed engineering done by guys who never had to fix their own car.
    It's going to need the rearend swapped out of the other one, though, it has a 3.73 open in it where the other was a 2.73 locker - the locker is better in mud and snow and the high gear would let me go 80 down the thruway all day long if I wanted.
  18. 2Loose
    2Loose
    '55 Chevy half ton, 455 Olds powered, 4L80e ****** and transfer, 4x4 conversion by me, ford 9" rear, ford 1.5 ton front axle. Front fenders and the grill bar are off of '55 Chevy commercial truck tractor, fit perfectly.
  19. gasserjohn
    gasserjohn
    47/48 pu....usually hauls a empty trailer to races in case need to tow something home ...drive the A to the track &tow it back >getting old now so tired at nite...
  20. TV
    TV
    I drive a Dodge Viper SRT 10, quite a truck.--TV
  21. For daily use- Studebaker of course.
    and sometimes an International Harvester
  22. eightbanger
    eightbanger
    2008 Tundra dbl cab 5.7. Does the job!
  23. Silent_Orchestra
    Silent_Orchestra
    from Omaha, NE
    Ya meen a Ram SRT 10? A Viper isn't much of a truck...
  24. chrislehr
    chrislehr
    from Austin, TX
    Thats cool as all hell.
  25. chrislehr
    chrislehr
    from Austin, TX
  26. First I had one of these, Landrover 110 6WD Ambulance, flat out it could do almost 90kmh!
    Then I upgraded to this, UH1D for AeroMedical Evacuation, I miss tac flying!
    And finaly I worked my way into one of these. One of the hardest things I ever accomplished. Special Operations Landrover JRA Long Range Patroll Vehicle.
    Doc.
  27. Bill Schickling
    Bill Schickling
    1940 Chevy 3/4 ton. Not fast, but fun.
  28. Rocky
    Rocky
    Classified Editor
    My 46 chevy mounted on a 78 chevy 4X4 ch***is..and my 85 chevy astro van with a 350 crate motor...both are workhorses. I hauled s**** metal with the 46 last winter when the s**** prices were high..
    Just traded the 46 off for a 54 Buick.......
  29. rixrex
    rixrex
    My work trucks have always been 3/4 ton Chevrolets, 350 TH400 with one-ton overloads in the back, receiver hitch for whatever..I drive an 86 I bought new for $12K, payments were $272 mth. Boy, we'll never see that again..Its got a 91 engine innit right now and truck is pushing 500K miles..The truck I retired before it was a 77 set up the same and was starting in on its second million miles on its third engine..only reason I retired it was the frame was starting to crack in places..I still have the"Blue Goose" 66 two-ton Chevrolet Bob-tail that was a mobile home mover and I put a tow sling and gen-pole on the back, its an 8-speed with a 292 six..I would like to have an early 50s Studebaker and am looking for one...
  30. cb1
    cb1
    from Wisconsin
