Spare Tires. What do you carry?
Discussion in 'The Hokey Ass Message Board' started by Slick Steve, Mar 31, 2009.
  1. Slick Steve
    Slick Steve
    from Indy
    So here is my dilema. My car has 2 different size tires, 560's up front and 670's out back, and 2 different wheels. I am just finishing a disc brake conversion and had to get new stock appearing wheels for the front, so I cant use the same wheels front & back. So here is my question, what should I do about carrying a spare while out on the road? Would you, carry 2, one of each size/wheel, or gamble and carry only 1, or none at all and count on a good ole can of slime? Thanks for help and sorry for the stupid question...
  2. Johnny1290
    Johnny1290
  3. What patterns are your wheels? They make multi-pattern wheels you could use as a spare. If they are the same pattern, use a disc brake wheel, it will still fit on the rear. Tire size is less of an issue.
  4. NoPaint
    NoPaint
    I actually carry tire plugs and a 12volt compressor. No jack or tools. If I can't fix it with that then I will just get a tow. If you have an American Express you get a certain number of free tows and fuel help with certain cards. With my business card I get 4 tows a year.
  5. Slick Steve
    Slick Steve
    from Indy
    Same pattern, same wheel, just different offset. front are for disc, backs are for drums. So a disc wheel will fit on a drum huh?
  6. I don't see why not.. Drum wheels don't alway fit on disc brakes though.
    Especially Ford.
  7. Corn Fed
    Corn Fed
    The only spare tire I carry is around my middle. Seriously though, I figure I'm not going anywhere that doesn't have a gas station at least every 15 minutes since my cars use so much gas, that they could fix any flat I have. I guess it makes a huge difference in your car too. I'm talking Model A's here, so I don't have any room for a spare or jack so it's really moot for me. Maybe if you have a huge 50's barge, you can carry spares and jack.
  8. Weasel
    Weasel
    Front - it's the end that steers the car - usually...:D
  9. Where are you driving, 1968? I haven't seen gas stations that fix flats with that much regularity since Nixon resigned.
    I plan on carrying a spare in all my cars. If it's a size differentiation I'll use the smaller of the two as a spare.
  10. hotroddon
    hotroddon
    With 145/15's on the front and 31-14.50X15 Dirt Track rears - I carry a cell phone
  11. Fix-a-Flat works great...unless you have a blow out. Then call AAA...
  12. Retro Jim
    Retro Jim
    If you carry one make sure it's the front one ! Odd size on the rear will work but odd size on the front and you will have a beast in your hands !
  13. outcasthb
    outcasthb
    With 195/15s front and 275/17s rear I also carry a cell phone and my AAA card
  14. Steves32
    Steves32
    from So Cal
    AAA card & a cell phone.
    I'm in a roadster- no room for much of anything.
  15. I dont think I can carry spare either, I have 205/60/15 on front and 235/75/15 on back, the problem is the rear end has a posi, and a small tire on one side would kill it I think. Also my spare tire well in the wag wont even fit a 215. Im thinking a couple cans of slime, and a small comp.
    Brad
  16. 55driver
    55driver
    I carry a 225/70/15 to match my rears, so not to mess up my Eaton posi.
    It will fill in for my 205/75/15 front long enough to find a tire store to repair/replace it.
  17. Busy B
    Busy B
    from Kalama, WA
  18. Comfortably around my midriff........
  19. MERRELL
    MERRELL
    get a spare rim for the discs and have the holes slotted...
  20. with all the different space-saver spares out there there should be something you can carry in most any car except the smallest T-buckets and roadsters.
    If you don't have room for that, how about some tools to break the bead and carry a couple of tire tubes to fit? I don't know that you could get them for super wide tires but most anything else should be possible.
  21. Jimmy2bottle
    Jimmy2bottle
    Very true!....
  22. 31fordV860
    31fordV860
    see pic..
  23. Spares??? We don't need no stinkin' spares, man... 2 cans of Fix a Flat that isnt age dated, and a cupla tahr plugs and a AAA or credit card does it fer me....
  24. pasadenahotrod
    pasadenahotrod
    from Texas
    Spacesaver spares are available for Ford in dual patterns 5 on 4.5 and 5 on 5.0 and for Chevrolets in dual patterns 5 on 4.75 and 5 on 5.0. We carry the Ford dual pattern in the trunk of the 32 3W mounted on the back wall behind the seat and next to the battery box.
  25. TV
    TV
    I carry a space saver spare, drilled for multi pattern. They are small and will work anywhere. Take one of the space saver rims and cut the center out, and weld a 1/2" plate in its place and drill a multi pattern. And whamo great spare. But small enough to carry around. --TV
  26. Mr48chev
    I kept the space saver out of my dads Olds 88 just for that purpose but usually I carried a Chrome reverse spare to clear the bed sides on the rear.
    If I go out my driveway and turn left it's two miles to a tire store, if I turn right it's fifty miles to anything that sells anything except beer, po p and potato chips. We have too many stretches with no service of any kind up here not to carry a spare or some sort of flat fixing setup.
  27. 21tat
    21tat
    Uhhhhhh, I agree with Doc.
  28. rick finch
    rick finch
    AAA & cell-phone. Although middle of Nevada on the way to Bonneville, I'd be f--ked!:eek:............Let me get back to you.
  29. gnichols
    gnichols
    from Tampa, FL
    For my 37 sedan, I had a 4x15 steel rim made so it would fit in the trunk where the OEM spare resided. I chose a tire size a tad larger than the front tires (but would still fit without rubbing on the fenders) and then of course fit on the rear if needed. Got a VW bug sized Metzler from Coker for the spare tire.. looked nice and I'm glad I never had to use it! Gary
  30. Winged Avenger II
    Winged Avenger II
    from Wisconsin
    I carry a can of that seal it up stuff and an air compressor
