Spare Tires. What do you carry?
Discussion in 'The Hokey Ass Message Board' started by Slick Steve, Mar 31, 2009.
  1. Model A Mark
    Model A Mark
    from dallas
    i agree here, if you run different role-out on the rear, it would be like turning the corner all the way home, i think it would smoke your differential if you run down the hiway with different size rear tires.
    i carry a small/skinny tire with the same role-out as the rear tire. it,ll get me home ..
  2. silent rick
    silent rick
    i have a space saver drilled for multi pattern, a plug kit and several cans of fix-a-flat. not just for me, but whoever i roll with. if one of us gets a flat, breaks down or has a problem, you just can't leave him there on the side of the road.
    here's something to remember too. if you have mag wheels that take a shouldered nut and have a regular steel wheel as a spare, it's a good idea to carry regular lugnuts if you every plan on using the spare. i've heard of someone having to borrow a lugnut from each wheel on another car because they forgot to throw the correct ones in the trunk for the type of spare they had.
  3. Von Rigg Fink
    Von Rigg Fink
    from Garage
    in the 53 i have a spare in the tire well,, the 28 not sure. Dont have the room and if it was hanging off the back I think it would spoil the look.
    Fix a flat, tire plugs and a 12 volt air compressor or small air tank possibly
    Credit card and the number to a good towing company (with a flat bed)
  4. 29nash
    29nash
    from colorado
    Two on the custom truck, one on the Nash Hot Rod, Green slime, spare tube in the goody box. That's the beauty of split rims, don't need a bead breaker, just an hour to do the job. Front view.jpg
    If I use a spare off the rack, when it goes on it stays on, it's replacement would become the spare.
    In 5 years, I've only had one flat. Nail puncture. Green slime brought it up long enough to get back home, but on a long trip the green slime would have only been a band-aid because the nail hole in the tube started to tear and eventually I would have had to use the spart tire. Consequently, because it made a real mess to clean up the tire, that was a bad idea and I would never use it again as primary, but will keep a can for absolute emergency, after the spares both go flat., and as silent rick says, to help out a friend in need :D
    Go figure. I don't personally know anybody that dont have a spare for the 'look', some that just didn't incorporate in the build. More of a missed priority I would think, because a reversed space-saver with slots for mis-matched front/rear patterns will fit somewhere on any ride. . I do have a S10 pickup without a spare because somebodyp stole it and I never have replaced it but I never drive it anyhow. I guess that truck would be cl***ified as "use for emergencies only", or "loan out to a relative in need", or "drive it if for some wierd reason both jalopys are down? :D
    AAA? Tow Truck? Will they meet me at the gas station if I make an appointment to pump my gas for me and wipe my **** after I use the ****per? Besides, I'll reserve my emergency tow clause for an actual emergency.
    Kind of self-sufficient that way...........
  5. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    I have a matching wheel/tire for the '50 Burb. With the Vette rear, I can't mix sizes lest I burn up the posi.
  6. H3O
    H3O
    when traveling, i carry two, but that's the nice thing about having a truck!! they're bigger than the fronts but smaller than the rears. so either way i'm fine.
  7. Elrod
    Elrod
    I run bias ply, so an inner tube patch kit, a tire bar and a small cigarette lighter air compressor.
  8. bigkev56
    bigkev56
    Do not mix tire sizes on rear axle if you have a No Spin or Posi setup.
  9. H3O
    H3O
    that's why carry two.
  10. Deuce Daddy Don
    Deuce Daddy Don
    I ALWAYS carry a spare! Never know which will need it, so I had an in between size of front 195 series, & 225 rear series, both radial 15 inch rims, in 300,000 miles, only had 1 rear go to pieces by the time I stopped, sure was a good feeling to be able to change it & proceed to next tire shop, 93 miles ahead!!--------------Don
