1956 Ford Wheel Alignment Specs?
Discussion in 'The Hokey Ass Message Board' started by crankcaser, Apr 6, 2009.
  1. crankcaser
    crankcaser
    from Houston
    Anyone out there tell me where I can find the wheel alignment specs for my 56 Ford Customline? I'm taking it to Ripley's Auto in Houston this weekend and they said it would help if I could produce them. Just did 2" drop springs , ball joints etc. and it needs aligned.
    Thanks!
    Hotrodjohn71 likes this.
  2. crankcaser
    crankcaser
    from Houston
    Never mind. I got em. The old Google magic box found it.
    Thanks anyways!
  3. Dammit
    Dammit
    from Canada
    According to the 1958 edition of Motor's Repair Manual, the specs are as follows:
    caster : +1/2 to +1 1/2 desired: +1
    camber: +1/4 to +1 1/4 desired: +3/4
    toe-in :1/16 to 1/8
    degrees toe-out on turns :eek:uter wheel 20 , inner wheel 24 1/2
    degrees steering axis : 7
    These specs are the same for all models, hope this helps.
  4. tommy
    tommy
  5. tltony
    tltony
    from El Cajon
    My advice would be to forget those specs and go as follows, as near as possible.
    Camber -1/2 degree negative
    Caster as much positive as possible, 5 or so + is pretty ideal. You won't be able to get that much though without some surgery.
    Toe's fine at 1/8 in.
  6. crankcaser
    crankcaser
    from Houston
    Great info! Thanks to all !!!
