I have removed the 55 Lincoln Turbo Drive ******, I will let you have it for free if you WILL use it.... It worked fine, but since I had the engine out I removed it to put a THM 350 behind My Lincoln 341... Is that wrong?
I have a friend that installed a 350, 700r in a 54 Lincoln. I'll ask him for details of the swap and photos if he has them
pics would be cool ,because i expecting a lot of problems with the steering link.... then the crossmember ?
I put a 390 in mine,not bad at all.It cam out of 62 t-bird,Need that big engine to move the weight of that car.I just coulnt see a small block in there
