Hot Rods 454?
Discussion in 'The Hokey Ass Message Board' started by intertubelip, Apr 13, 2009.
  1. intertubelip
    intertubelip
    I have a 52 ford coupe with a bbc. But none of the valve cover gaskets fit. I had to cut the gasket tabs off to make them fit. I went to many auto parts stores, they checked 396, 427, 454. and no match. the holding tabs do not match up. Jim
  2. ...doc...
    ...doc...
    from Houston
    so,...are you asking a question, or making a statement?
  3. Retro Jim
    Retro Jim
    A picture would help to understand problem !
  4. the machine
    the machine
    I have had to cut the tabs on the out side of the gasket to install them, if thats what your talking about.....
  5. intertubelip
    intertubelip
  6. intertubelip
    intertubelip
  7. 69fury
    69fury
    from Topeka
    sounds like you have aftermarket valve covers that don't need a tab to hold the gasket in place while you install it. if the shape and bolt holes line up then you're money. sometimes you just gotta call a duck a duck.
    now if your old gaskets dont match (size/shape/boltpattern), then take a pic of the motor and post it.
  8. intertubelip
    intertubelip
