what is this
Discussion in 'The Hokey Ass Message Board' started by hiboy, Apr 14, 2009.
  1. I found this old chevy 1ton dumped closed to the house and just had to look. A sticker in the fenderwell says 350cu but what kind of motor is this?
  2. BBYBMR
    BBYBMR
  3. 61TBird
    61TBird
  4. sdluck
    sdluck
    Looks like oldsmobile.
  5. Dan Hay
    Dan Hay
  6. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
    That is the fabled chevy v8 engine.
    Many men have devoted their entire lives to the chance of finding one of those ultra rare motors.
    Rumor has it that you are more likely to see a unicorn with a mermaid riding it, than finding one of these.
  7. Revhead
    Revhead
    from Dallas, TX
    Looks like an Olds to me too.. definitely not a Chevy SBC
    compare to this olds 350.. Especially look at the water transfer pipe from the thermostat housing to the water pump. Also note the valve cover shape and number/location of bolts. Oil fill tube as well.
  8. JohnEvans
    JohnEvans
    from Phoenix AZ
    POS Olds diesel converted to gas ?? Ain't a Chevy that's for sure.
  9. TomP64
    TomP64
    from Vancouver
    Olds, and s**** too i'd guess.
    Diesels don't generally have carbs but chances are it's the original Olds 350 diesel converted to gas.
  10. Kid Jeff
    Kid Jeff
    Kinda looks like maybe a diesel? Definately not a 350. Looks like s**** to me!
    -Jeff
  11. vertible59
    vertible59
    Look at the fuel gauge...does it say diesel fuel only? Looks like one of those infamous GM diesel engines, based on the Olds 350 V-8, or whatever Olds engine the General used to source these gas conversion monstrosities.
  12. It seemed to have a q-jet so thought it was gas. Didn't think of a conversion. Its s**** anyway.
  13. R Pope
    R Pope
    The truck had a 350 diesel, and when it cratered an Olds was swapped in. The POS diesel was based on the Olds block so the g***er bolts right in.
  14. enginebloch
    enginebloch
    from norfolk va
    Oldsmobile gas engine. From what I understand you cannot just throw a manifold and carb on one of the diesel engines.
    Olds used the same block design for the 350-455 engines so it is difficult to tell at a glance what it is. The casting number is on the block just behind the water pump, an ID number is stamed on the oil fill tube, and the heads will have a letter on the front of the drivers side head or rear of the p*** side.
    If it has a manual transmission, the bellhousing would be worth having for a buick/caddy/poncho/olds powered car.
  15. RichG
    RichG
    ...maybe an industrial motor?
  16. malibusleeper
    malibusleeper
    definitely a olds gas engine. looks like a letter C on the corner of the head which would mean its a big block. I always thought the diesel 350s only came in the half tons for mileage and couldnt even be towed with due to having zero balls
  17. malibusleeper
    malibusleeper
    just found this on 442.com:
    C '67 - '69 425 80 394548 A/C '68 H/O's. Toro's and 442's got big.
    455 valves. Rumored to flow the best of all BB
    heads. Can still be found.
  18. turdchazer
    turdchazer
    from Spokane
    I dont know what it is, but please don't put the damn thing in a Ford!
