Custom length driveshafts in the south metro Minnesota?
Discussion in 'The Hokey Ass Message Board' started by Jason455, Apr 16, 2009.
  1. Jason455
    Jason455
    I made a driveshaft for my 32 chevy but it I either did not get it right or it needs balancing. Anyone know of a good driveline shop in the south metro in Minnesota? Ive called around without much luck. Thanks Jason
  2. Ole don
    Ole don
    I have been away for a while, but I used Clutch and U Joint on 41st and Hiawatha. Are they still there?
  3. Retro Jim
    Retro Jim
    Gotta have it balanced !
  4. Catco in Burnsville , they also have a location in Rochester...maybe that's closer for you
  5. titus
    titus
    Ive shortened about 10 of my own driveshafts and never had to have one balanced yet, maybe im lucky, i dont know, i know it kinda of one of those taboo topics, shortening your own driveshaft!
    I have better luck doing it myself, i had one shortened and balanced long ago and it was ****ed up, i made a new one myself and its still working fine 7 years later.
    JEFF
  6. Jason455
    Jason455
    Well I always made mine too, but I noticed this one moves up and down slightly when I spin it. At freeway speeds it vibrates badly. Now the seal on my axle has started to leak. Figured Id bring it in an see what they say. I looked up catco and noticed theres one in newport. I will head up there. I dont want to go to burnsville unless I have to, way to busy there. Thanks everyone.
  7. Rick Thompson
    Rick Thompson
    Alliance Vendor
    Universal drivelines in White bear lake MN. not exactly the south metro but well worth the drive
  8. partsdawg
    partsdawg
    from Minnesota
    Inland Empire driveshaft in Chanh***an
  9. 55FORDWGN
    55FORDWGN
    When I had one done 7-8 years ago at Clutch and U-Joint the guy wouldn't balance it for me, he said most of the time they are fine and if it needed balancing it still would cost the same if I brought it back for balancing. Never had it balanced, never needed to.
  10. i hope you called them before you left...i'm not sure if EVERY location does driveshafts , i don't know about Newport , they may send it over to Burnsville. i know Burnsville and Rochester do
    and yes , i have cut many of them myself with no problems without balancing when i had access to a bigger lathe. if i had a steady rest for my Logan i would still be doing them
