Question on wire wheels
Discussion in 'The Hokey Ass Message Board' started by kmfdm242, Apr 19, 2009.
  1. kmfdm242
    kmfdm242
    from phx az
    I am going with 40 drum brakes on front. I want to run wire wheels. I want to go with a tall wheel I have seen 18's and I think 19's. What year did they make them? And will I need to use a spacer ring on these?
    Thanks.
  2. yes, you will need that ring
    18" is `32 Ford , 19" is 30-31 Ford .....FYI, 21" is 28-29 Ford , 17" is 33-34 Ford , 16" is 35 Ford
  3. kmfdm242
    kmfdm242
    from phx az
    I wasn't aware of the 21" wheels. What wheels don't use the spacer with the 40 drums?:confused:
  4. Carter
    Carter
    40-48 ford solids don't need the spacer.
    All of the Ford wires need the spacer as far as I know.
    Dave
  5. Jupiter Zone
    Jupiter Zone
    While tall wires do look nice 16's sure help get the CG down. Another plus to the 16's is you have less wire length from hub to the rim. But on the other hand a good 16 is three to four times as much. My HO for what it's worth.
  6. kmfdm242
    kmfdm242
    from phx az
    Thanks for all the info guys.
  7. unclescooby
    unclescooby
    from indy
    Is strength a big concern on these wheels when running a V8? I'd be concerned about a hard launch on some of these skinny old rickety things. I'm guessing much of that would be alleviated by the fact that it's all wheels spin and no hookup but still....
    do these actually hold up?
  8. Curly Hand
    Curly Hand
    from Tucson
    Sorry for intruding on the conversation. Is it true that a "32" Ford wheel had exactly 32 spokes on each rim? If so I think that is pretty darn cool.
  9. nailheadroadster
    nailheadroadster
  10. that i don't know....but i do know that the hood hinge is 32" long on a `32 ford , and 33" long on a `33 ford
  11. unclescooby
    unclescooby
    from indy
    That's a great thread but still leaves my question about the strength issue?
  12. Winged Avenger II
    Winged Avenger II
    from Wisconsin
    are you talking chrome wire wheels??-not on a 40. painted wire wheels wolud look good.
