Can I run Radials on 16" ford wide 5 rims?
Discussion in 'The Hokey Ass Message Board' started by 35fordrat, Apr 20, 2009.
  1. 35fordrat
    35fordrat
    I have asked a few of my friends and they cant seem to give me a straight answer...Do I have to us bias ply tires and tubes on my 16" rims or can I seal the rims w/ something and use a tubeless radial tire? If I can use a radial tire, can some one tell me what size will fit my rim....My current set up is 600x16 bias ply tube tires on wide 5 bolt pattern rims...Thanks for your help guys...
  2. H3O
    H3O
    how wide are your wheels?
  3. nitrohonkey
    nitrohonkey
    I would like to know too. I was told air will leak past the rivets. I had a pair widened and they used late model rims/bells to make them tubeless but that gets spendy as the centers are an odd size.
  4. 35fordrat
    35fordrat
    I am not sure..??? The only markings i could find on the tire are 600x16 on the fronts and 650-16 on the rear...
  5. 325w
    325w
    Lots of the "A" guys are running them now. Their using the 16's and buying radials on the road cars. Might check the "A" web sites.
  6. JohnEvans
    JohnEvans
    from Phoenix AZ
    First they DO make radial tubes and they can be used in tubless radial tires. Second mount 'em up tubless and see if they leak,if they don't no prob. If they do add tubes.
  7. havi
    havi
    Maybe contact Coker tire, too?
  8. Stu D Baker
    Stu D Baker
    from Illinois
    I thought I saw something about radial tires transfering stress to the wheel, which may exceed the engineered limits of the older wheel? I'm sure there are hambers who have knowledge about this. Stu
  9. Would that stress be due to higher inflation pressures?
    My car trailer instructs you to inflate the tires no higher than 50# - which is the recommended max pressure for the tires as well.
    Kinda surprised me, never saw an inflation limit for a wheel before.
  10. roddinron
    roddinron
    Been quite awhile since I messed with any wide 5's, but couldn't you clean the inside real good, and smear a little JB weld around any rivets that might leak? But I'd still ask around about the safety of combining them with radials.
  11. Hotrod Lincoln
    Hotrod Lincoln
    Wheels rated for radials are a little thicker construction, not because of inflation pressures, but side loading in a turn. The way a radial transfers load to the bead area of the rim is different, due to the construction of the sidewall. On an older, possibly lighter-duty rim, there's at least a possibility of a rim flange failure in a hard turn.
    For all practical purposes, the older rims will probably work OK, but the tire manufacturers won't endorse the use of radials on a bias-ply rim for liability reasons. If the rim is airtight, and you don't go road racing, you'll probably be OK running tubeless. I suppose a good welder could silver-solder or braze over the rivet head if you find one that's leaking air, but running a radial-rated tube would be simpler with a leaky wheel.
    Jerry
  12. evil clown
    evil clown
    from Verona, WI
    To seal the rim I would simply use a good silicone caulk on the welds and rivets before mounting the tires. That's what we use for aftermarket ATV rims that have a tendency to leak at the welds. We don't have any leak problems anymore. You could run a tube as mentioned, but a little silicone will seal it right up.
    I'm no engineer, but I find it hard to believe that a rim from the 30's or 40's (except maybe wires) wouldn't be more structuraly rigid than a newer, usually lighter rim? I'm ***uming that the rim is in good shape to begin with, not some rusty old rim.
    That's my two cents worth. :D
  13. Marty McFly
    Marty McFly
    I have never heard this one before.
    Marty McF.
  14. Butch11443
    Butch11443
    I'm running radials on a set of "35" spokes. No tubes and no problems. Got the tires at local Goodyear dealer.
    Butch
  15. H3O
    H3O
    the older wheels tend to flex and that's why you see wheel covers and trim rings fly off. had one of my trim almost come off because of that but i don't have them on anymore.
  16. Cosmo49
    Cosmo49
    Running 215 85R 16's (no tubes) for 44 K miles on '49 stock Chevy rims. Ten + years on a daily driver year round.
  17. alchemy
    alchemy
    Radials have a lot more flex in the sidewall, and the older wheels don't have the safety bead to keep the tire snapped into place. Some say the radial will roll off the seat if pushed sideways too hard.
    A radial tube inside your radial tire is supposed to prevent the loss of air if the tire becomes slightly "unseated" for a moment.
  18. GassersGarage
    GassersGarage
    I run em on 16" wire spokes no problem. I got the Coker WW Cl***ics in 5.60 and 7.50, tubeless. There's a warning to run 41# of air.
  19. SleightsburghMC
    SleightsburghMC
    No problems on my 46 sedan. Guess the paint I spayed them with was more than enough to seal the rivets. Ive run them for two years and no leakage.
  20. shainerman
    shainerman
    I have a set of radials and bias on 2 of the same sets of rims. The radials work just as good as my Cokers and ride much nicer. I was having the same conflict and just said screw it and mounted them up. No problems now for over a year.
  21. fridaynitedrags
    fridaynitedrags
    Use RTV to seal the rivets like evil clown said. If you look at some of the Centerlines, they have a strip of RTV all the way around the inside of the wheel.
  22. chopper99
    chopper99
    I agree and I believe the important issue here is the safety bead.
  23. MOCO559
    MOCO559
    Answer:
    Always try and use and tire that has the same tread width as the wheel width.
    example: 600R16 had tread width of 5.00" therefore rim width should be 4-6.0" wide
    215/70R16 has tread of 7.0" therefore rim width should be 6-8" wide
    Coker makes radials with same specs as 550-75016 that way you can use your O.E. wheels. but you still have to use a tube. Those old wheels don't have a safety bead.
  24. Retro Jim
    Retro Jim
    They do make a radial for that rim but you will have to use a radial tube too . Gonna cost allot of $$$$$$$$ ! :eek:
  25. deuceroadster2
    deuceroadster2
    Alchemy hit the nail on the head, the rim doesn't have the safety bead that the newer rims do.
  26. Hackerbilt
    Hackerbilt
    Isn't a safety bead to help keep an UNDERINFLATED tire on the rim?
    For the "common" man or woman who'd rather ride on the sidewalls then check his/her air pressure...or taillight bulbs...or oil level etc, etc, etc...
  27. fuel pump
    fuel pump
    from Caro,MI
    These are Coker Cl***ic 16" radials that use a tube. I don't see why they wouldn't work on wide five:
  28. A friend of mine runs spoked wide 5s and radials and he used gas tank sealer to seal the spokes and has never had a low tire in almost 2 years. No problem with the wheels being over stressed but he does'nt slam into corners either. Just a thought
