1935 Ford Wire Wheels..info needed
Discussion in 'The Hokey Ass Message Board' started by 16ozSchlitzMan, Apr 19, 2009.
  1. I have a chance to buy 4 original 1935 ford wire spoke wheels...does anyone have any info on the bolt pattern on these wheels and maybe who made these...i need 5 - 5 1/2" wheels..i only know that these are 16" rims..see pic below..
  2. the bolt pattern on 1935 Ford wheels is 5 on a 5-1/2" diameter bolt circle
    mkal88 likes this.
  3. Squablow
    Squablow
    Yup, 5 on 5.5". Also keep in mind that on some brake drums you'll need a round spacer to go behind the wheel to keep it mounted flat. There are a few threads on those, someone makes them and they're really cheap, supposedly the right sized piston ring works too. I think the wheel will bend or won't sit flat if you bolt them to a later drum without the ring in place, due to the way the original Ford drums were designed.
  4. Thanks guys...the guy wants $200.00 for them...should i try less...i just blew a chance on ebay..guy had 4 wheels (ford wires) all blasted and cleaned with new caps for $225.00 plus $60.00...well...these ended going for $405.00..the buy it now came off once the reserve was meant..the ones above for $200.00 are in great shape..ONE problem with these... have to travel 200 miles to get them...anything i should pay attention to when i check these out....
  5. G V Gordon
    G V Gordon
    from Enid OK
    Like has been mentioned above these will only mount directly on early Ford brakes, later brakes (even early Ford juice brakes) need at least the spacer ring and at most an adapter as later drums (think Ford PU) drums won't fit inside the wheel hub.
    Wheelkid here on the board has what ever you need as do others, he is an Alliance vendor.
  6. Squablow
    Squablow
    $50 each isn't a bad price, that's probably going rate for decent ones. The blasted ones with new caps for $225 was a bargain. I have an extra set of four that I'm having blasted and then they'll be for sale, I'll probably want $200 for that set, no caps, and I can ship them.
    If you do go to look at these, the common rust places are around the valve stem hole and on the inside lip of the beads (typical old steel wheel rust spots). Also check for bent spokes and wobbled out lug holes.
  7. If this is true then I have an issue...my front axle is a 48 F-1 and the rear is a 9" rearend off a 69 Bronco..Can anyone give me more info on this issue...I might have to re-think this....
  8. yes , while your wheels and front brakes and rear end all have the same 5-1/2" bolt pattern....they will not bolt up. you will need a thick spacer or wheel adapter
  9. Your going to need spacers. Wheelkid is the fella you need to talk to on here. Has already been said once.-Weeks
  10. kmfdm242
    kmfdm242
    from phx az
    If Wheelkid dosn't have them I just saw them on MT car parts website for 20.00.
  11. ABONEDEUCE
    ABONEDEUCE
    from australia
    Hi there iam going to run 35 wires on my 5w and have speedway wheel support rings but the are not thick enough its like they have to be about 1/4 thick has any one else had this issue thankyou jason form Australia.
