fomo co transmission
Discussion in 'The Hokey Ass Message Board' started by ChucoTownHotRods, Apr 21, 2009.
  1. ChucoTownHotRods
    ChucoTownHotRods
    Does any body no what other ****** would fit a 1958 edsel engine its a 361 dont have the original want something quick want to drive it already engine is all done what else would work:D
  2. KULTULZ
    KULTULZ
    Is it push ****on shift or lever shift?
    If lever, any CRUISE-O-MATIC of the period (58-60). The 58 EDSEL only used the Single-Range (actually a FORDOMATIC). The 58 FORD used both and the shift indicator and linkage for the DUAL-RANGE may be able to be used on the EDSEL.
    A FE C6 would work on it also. Would have to make a few modifications.
  3. AnimalAin
    AnimalAin
    As mentioned above, the cast-iron Cruise-o-Matic and FE C6 are good choices.
    If you are interested in a more modern trans, there are vendors that can adapt the AOD. It has its advantages (overdrive), but is likely to be somewhat more expensive.
    If you have a preference for GM transmissions, there are adapters available for them as well; maybe a good choice, but probably not too cheap.
  4. KULTULZ
    KULTULZ
    Great idea, but as mentioned, expensive.
    See adaptor below-
  5. ChucoTownHotRods
    ChucoTownHotRods
    cool were can i get one of those adapters and what about the drive shaft i have the original one what would i have o do to it lets say if i am using the ****** thats in the picture what is that that gm ******.:D
  6. KULTULZ
    KULTULZ
    That is a FORD AOD shown. I do not speak GM, MOPAR or ASIAN/EUROPEAN.
    http://www.transmissionadapters.com/ford_fe.htm
