Hello From Wisconsin... 1947 Ford Turbo Diesel
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by 47Ford - 1.5Ton, Apr 22, 2009.
  1. 47Ford - 1.5Ton
    47Ford - 1.5Ton
    Hey Guys..... figured I'd finally drop by and show my 'big rig' in progress....... About ME? 24 yr old recent college grad from the University of Minnesota with a BS in Mechanical and Jet Turbine Engineering... moved back to my hometown Green Bay, WI.....and lucky enough my job allows for long nights in the garage with the beer fridge full of nothin better then Busch Light......... so to no further avail..... enjoy!
    1947 Ford 1.5 Ton 'Heavy' (No F-series Yet)
    ***mins 4BT 4 Cylinder Turbo Diesel
    Ford ZF S542 5 Speed Manual OD Trans (From a 94' F 350)
    Sitting on a 1987 GM 2 Ton Ch***is
    Slam Specialties Air Suspension Up Front
    Dual 33 Gallon Saddle Tanks from an Isuzu NPR COE
    Work in progress... hopefully drives this summer....
    Right After I picked it up....
    The new GM Ch***is and ***mins Turbo Diesel
    The Motor and ****** now rebuilt and finished...
    MOCK MOUNTING
    MOCK MOUNTING CONTINUED
    And Because Im an engineer......everything is 3D modeled in Solidworks
    Give your thoughts and happy to be here guys
    ~Mike
  2. X38
    X38
    Well, it's a truck...and this is a traditional hot rod and custom forum...
  3. Lucky667
    Lucky667
    from TX
    Hello & Welcome to the HAMB from South Texas. Don't drop the ball, keep posting your progress.
    Good Luck.
    Lucky667
  4. norwich25336
    norwich25336
    from Michigan
    Now that's a truck! The best of both worlds. Good work.
  5. Max Gearhead
    Max Gearhead
    from Wisconsin
    Welcome from southwestern Wisconsin.
    Max
  6. Gerg
    Gerg
    welcome from sheboygan
  7. 1fineline
    1fineline
    Well, you'll have one of a kind! Think it cool you're doin' your own thing.
  8. bobwop
    bobwop
    from Arley, AL
    I like it. Only question I have is the gap between the back of the cab and the bed. Looks like an air tank to me. IMHO it would look better if the bed went forward to within 3-4" of BOC and then hide the tank or even place it in the bed. Looking good, keep up posted. Perhaps a thread on the HAMB? Welcome from Jefferson.
