1929 chevy full sheet metal kit car
Discussion in 'The Hokey Ass Message Board' started by 31ratcoach, Nov 30, 2008.
  1. 29nash
    29nash
    from colorado
    The pictures are already here on one of these, plus boo-koo more info.
    http://www.jalopyjournal.com/forum/showthread.php?t=313654
    http://www.jalopyjournal.com/forum/showthread.php?t=288419
    http://www.jalopyjournal.com/forum/showthread.php?t=323303
    http://www.jalopyjournal.com/forum/showthread.php?t=323290
  2. displacedokie
    displacedokie
    from oklahoma
  3. 35Chevy.com
    35Chevy.com
    from New Jersey
    Toddster
    What size tires are you running, also any pics of the rear spring setup?
    Today I put the body of my 35 back on the frame after installing a s10 rear needless to say it sits very high. Im looking for options to get it lower
    Gary
  4. 34toddster
    34toddster
    from Missouri
    Gary, I used 225/70 x 15 with an 8.5 wheel that is too wide that might work with an S10 they are very narrow. I used a GM G body rear. I'll try to put all of my pic's on an album but need some help from Nash or someone that knows how to do it... Thanks, todd
  5. Joe Tx
    Joe Tx
    Little bit more work on my body. Doors hung and reinforced on inside, hinges and latches installed. Using '32 ford handles--because I had them and they are neat. Hinge post completed and the windshield surround pretty much finished. The top channel is removable to install gl***. Joe.
  6. PBRmeASAP
    PBRmeASAP
    Looking good Joe. Love them open chevys!
  7. Ghost28
    Ghost28
    Yeah way to go Joe. Your car is looking good. I better get back in the garage, you guys are making me look bad...ghost
  8. Joe Tx
    Joe Tx
    Getting close to trying the body back on the frame. Does anyone have a rumble seat trunk latch or parts they might want to part with?? Need a latch, striker, and handle. Thanks, Joe.
  9. 29nash
    29nash
    from colorado
    Looking good Joe Tex
  10. thebrassnuckles
    thebrassnuckles
    i have my 31 coach for sale if anyone is interested. dot want to sell it, but finances do not allow me to keep it. its i the cl***ifieds. photos in profile.
  11. Joe Tx
    Joe Tx
    "Re: '31-2 chevy coupe splash aprons
    Just and FYI for you.....coupes and sedans are the same....but 31 and 32 are different. You are building a 31 correct? I'd trade you a 32 for a 31..."
    <!-- / message --><!-- sig -->
    A while back you posted this on one of my threads, what's the difference between the '31 and '32 running board splash shields? Will the '32 work on a full fendered '31 with '31 fenders? Thanks, Joe.
  12. HRK-hotrods
    HRK-hotrods
    I have a question about the running board splash aprons too...
    On my 30 Coupe, it came with 2 drivers side aprons, both supposed to be NOS and 2 different lengths. In the pic below, the one on top is longer than the one below, by 3 inches or so(I didn't measure and they are buried in the shed right now. The original one that was still attached to my running board was in very poor condition with the ends rotted off so I couldn't match it up with that...
    Any idea on what is what?
  13. 34toddster
    34toddster
    from Missouri
    My 31 2 dr coach is 63 inches long
  14. 29nash
    29nash
    from colorado
    I would call Bow Tie Reproductions, they sell new repos, and might tell you the differen dimensions.
    Phone: 440-327-4800 - Fax: 440-327-9599
  15. mobeydick
    mobeydick
    from Georgia
  16. valkokir
    valkokir
    from DeKalb, IL
    Definitely not a '29, That's a '31 hood. and '30-31 visor. The wheelbase changes in '31 to 109" but that's not a surefire check since someone has swapped the rear axle.
  17. Ghost28
    Ghost28
    In the post 495 on this thread. The 30 hood side shown on the ground confirms that your girl friends car is a 31 independence AE 3 window coupe. And not a 29 or 30. The 29 front sheet metal between the frame horns is all wrong for your car...ghost
  18. Ghost28
    Ghost28
    the shorter of the two splash aprons should be for your 30. The longer one should be 2 inches longer and would probably fit the longer 109 inch wheelbase 31
  19. 34toddster
    34toddster
    from Missouri
    Does anyone want my 31 2 dr coach gl*** for patterns? I just got all of mine back from the gl*** shop and it looks like a fit.
  20. TKEBH964
    TKEBH964
    from MO
    Just got started on a 29 chevy coach that my dad has had apart for the last 25 years. Amazingly, after 25 years of storage, in about 4 differant garages, a few attics, we only seem to be missing the rear sill piece of wood.
    These are the beginning and end of Day 1. The wood in the second picture is mostly just clamped together till we get a better idea of how things need to be aligned.
  21. 35Chevy.com
    35Chevy.com
    from New Jersey
    Welcome to the Chevy wood club.
    looks like you have the makings of a great car
    Gary
  22. RayMiller
    RayMiller
    I started my 28 out with tacking the body together and then building a 1/2 x 1/2 frame on the body panels(temporary will need more strength), but I have a coupe and it had no top. my top came off of a 29 oakland, plus I chopped the **** out of mine.
  23. RayMiller
    RayMiller
    mine has a long way to go still but its been a fun project, when all the wood is gone and you have no pattern you have to play 1 to 1 scale modeling.
  24. 35mastr
    35mastr
    from Norcal
    I have a Pontiac that is similar. What did you do about the deck lid. Did you just slide it back into the p***enger compartment? If its like mine. Those lids just had a boot to seal them which really ****ed for weather.
  25. 35mastr
    35mastr
    from Norcal
    Wow,This thread has exploded with GM"S since the last time I saw it. I did not know that there were this many on the HAMB.
  26. HRK-hotrods
    HRK-hotrods
  27. RayMiller
    RayMiller
    I have'nt had to modify the back of the body, I cut the oakland lid to fit. the decklid is in terrible shape and I think im gonna cut it down.
  28. RayMiller
    RayMiller
    35mastr I have a 35 standard 4 door, door you have any pics of you 35?
  29. TKEBH964
    TKEBH964
    from MO
    Gary,
    Thanks for the kind words. We are pretty excited about the project. Dad did a lot of ch***is work 25 years ago, and we ahve collected a large number of pieces over the years so things should go pretty quick once we get the body figured out.
    The front axle has been dropped 4", it has a chevy II rear end, disc brakes up front, vega steering, and a 327 ready to go.
  30. 34toddster
    34toddster
    from Missouri
    Ok I washed it outside for the first time and drove it around the block, no exhaust but who cares!:)
