Ford302 stroker????????
Discussion in 'The Hokey Ass Message Board' started by draggin breath, Apr 25, 2009.
  1. draggin breath
    draggin breath
    I just picked up a mustang to kill for driveline pieces for my '55 pickup. The engine runs STRONG,has aluminum rockers,solid lifters,edelbrock intake and a 780 leaker. Supposedly it is a 347 stroker;been thru several owners. How can I tell if it has a stroker crank without dismantling the engine? i'm going to switch the pan,so it will be open;what should I look for???????????
  2. AnimalAin
    AnimalAin
    Stock 302 has a 3.00 stroke, while the 347 has a 3.40 stroke. You should be able to tell with the pan off.
  3. 5wcoupehunter
    5wcoupehunter
    from FLORIDA
    I bought this one for the 347 A-4 block ported victor jr heads then took it apart for my coupe.
      255.3 KB
      256.3 KB
  4. 61falcon
    61falcon
    the bottom of the cylinders will be notched to clear the rods if its a stroker.
  5. Retro Jim
    Retro Jim
    You will see the difference when you remove the oil pan .
  6. draggin breath
    draggin breath
    Retro Jim,need an answer that has substance,not one from a rat rod viewpoint,please be helpful.
  7. tjm73
    tjm73
    61falcon is correct. All 347's need to have the bottoms of the cylinder bores notched for con-rod bolt clearance. If the pan is off, and the rod-bolts have clearance notches and nearly touch it is likely a 347. The other common 302 stroker is the 331. It has a 3.25" stroke crank. It's a .030"over/3.25" stroke combo. They don't need to have the cylinders notched if they have I-beams, but may need them notched if it has H-beams.
  8. dakotajayne
    dakotajayne
    from 3c1
    My 347 **** crank sez "****", also look for capscrew rod bolts and rod much stouter than the stock units. The engine may have a girdel and its easy to measure the stroke with the pan off.
  9. 39 All Ford
    39 All Ford
    from Benton AR
    I am sure there are a few ways to get a rough stroke measurement with the pan off, knowing the different strokes for 302, 331, and 347, it should be reasonably easy to figure it out.
    Maybe a magnetic stand for a dial caliper as a reference point,,,,
  10. Omega
    Omega
    from Mass
    Let us know what it is, when you figure it out..im anxious to know (im a mustang guy :)
  11. Drive Em
    Drive Em
