DO all 235's suck? or just mine?
Discussion in 'The Hokey Ass Message Board' started by 48_HEMI, Sep 18, 2004.
  1. 48_HEMI
    48_HEMI
    Hey I was never going to dump the HEMI"S for inliners BUT, I traded a built 396 that I had aquired over the years for very little cash, for a 57 chev 3/4 ton with a 235 and truck 4 speed. had it for six month and never registered or drove it off the property. one day idling it popped and started running rough, died and wouldn't start again. being the v-8 guy that I am I figured it jumped time and needed torn down. being the procrastanator that I am, I towed it to the orchard and parked it for six months (or so!) then when I came across a nice little 235 for minimal cash. I decided it needed to go in the truck. I've had it running for less than a month and a couple days ago it developed a miss. I started with the obvious things, ignition, timing, carb. fi****ly did a compression check number 4 cylinder has zero compression. zip the needle on the gage doesn't even wiggle. never seen that before.
    From memory of days gone by when I trashed the **** out of these old motors you couldn't kill one with a club and now I've had two in row go to **** with tender care. [​IMG]
  2. tatts
    tatts
    try beating the **** out of it. if that dont work use a bigger hammer
  3. Upchuck
    Upchuck
    from Canada BC
    maybe the rod cap came off and the pistons not moving! [​IMG] [​IMG]
  4. 48_HEMI
    48_HEMI
    that is exactly my thoughts. I haven't figured out how to check the botom end without draining the oil haha [​IMG]
  5. CLSSY56
    CLSSY56
    I had a 235 once, wouldn't own another one...
  6. dabond
    dabond
    Find a 261 or better yet a 302 GMC.
  7. HOTRODPRIMER
    HOTRODPRIMER
    I had one in the Chevelle from Hell,,,,It was a piece o' ****!,,,,,The car and the engine!HRP
  8. Gr8ballsofir
    Gr8ballsofir
    no valve no compression... Holed piston maybe??? What year is the 235? The early ones had a splash oiling system that ****s REALLY bad...
  9. antichrysler
    antichrysler
    I had a 235 and I loved it. But I have a hemi too, and it's da bomb. We should all wise-up and stick to mopar and poncho motors, and buick nailheads. Weird motors work better. Everyone I know with a 350 has blown it up. Good luck either way.
  10. OldCarPilot
    OldCarPilot
    from Bel Air MD
    Hell I just put a 235 back together that hadn't run in 20 years. Fired up as soon as it had gas!
  11. 53_210
    53_210
    Mine seems to work pretty good... Leaks like crazy though. And I don't really beat on it too much. I've seen 0 compression on a 454 once. Had 150 with oil in the cylinder though.
  12. SimonSez
    SimonSez
    Check the valve adjustment. If it is a solid lifter motor, you can get 0 compression if the valve is adjusted to tight and staying open.
  13. zman
    zman
    from Garner, NC
    I don't know about yours, but mine did 3000 miles round trip to the HAMB Drags and developed a miss on the way back, needed a cap and rotor and back to normal. I'm still putting a Nailhead in its place though. I wanna tow...
  14. 48_HEMI
    48_HEMI
    Zman I checked all the normal thing first then pulled the plug wires one at a time with the engine running. the spark is jumping but the cylinder is not firing. thats when I did the compression check.
    It a 57 motor with a full pressure system. I guess I'll have to drop the pan and find out what going on. It pulled a trailer with my 49 pontiac to the unfinished nationals and back and never missed a beat [​IMG]
  15. zman
    zman
    from Garner, NC
    If you put a few squirts of oil in the cylinder do you get any compression?
    Sometimes it'll get rings to temporarily seal.
  16. Upchuck
    Upchuck
    from Canada BC
    48Hemi you run that rig up here and I'll swap you straight across for my f1! if its the grey one in that picture [​IMG]
    and that will solve your 235 problem [​IMG] [​IMG]
  17. 48_HEMI
    48_HEMI
    let's see the f-1 [​IMG] yeah its the grey ghost in the photo, with the 235 out of this green piece of **** [​IMG]
  18. bigron
    bigron
    [ QUOTE ]
    [/ QUOTE ]
    use the bigger hammer from the git go. don't force it!!
  19. visor
    visor
    from Missouri
    48 hemi, before you pull the pan,
    check the valve train man.
    Pull the valve cover and the rocker cover,
    rotate the motor and check to see if the valves
    are seating.
    BUT FIRST..........
    Stick a piece of vaccuum hose in the dead cylinder
    and rotate the motor and the piston will push it
    back out if its still connected to the crank.
    (If its not ,that would be pretty hard to believe.)
    Don't give up on the old inliner, they have outlasted
    most of them. [​IMG]
    OPOSSUM BENDERS
    Central Mo.
  20. 48_HEMI
    48_HEMI
    I pulled the valve cover before I did the compression. I was hoping for a stuck valve or bent push rod. everything is working fine [​IMG]
  21. DIRTYT
    DIRTYT
    from Warren,MI
    i have more 235 parts then i know what to do with. if u need any thing for it shoot me a pm. i even have a 61 canadian pontiac (chevy) 261.
    Bryan
  22. Upchuck
    Upchuck
    from Canada BC
    [ QUOTE ]
    [/ QUOTE ]
    that "piece of ****" would look much nicer in my yard than yours [​IMG] got a couple kids dieing to labour away at your house til its worked off [​IMG]
  23. KlunkyMcShift
    KlunkyMcShift
    My 235 is running still, in the same truck, with the same head gasket as it had when it came from the factory, 44 years ago and about 89000 miles ago. Sure now it's blowing oil out of everything, but it still friggin runs! [​IMG]
  24. 48_HEMI
    48_HEMI
    [ QUOTE ]
    [ QUOTE ]
    [/ QUOTE ]
    [/ QUOTE ]
    I'll say it one more time! lets see the F-1 [​IMG]
  25. Upchuck
    Upchuck
    from Canada BC
    this is the last picture of it before I put it away for winter, it has a newer box on it that I have to get some conveyor belt or something to fill in the gap along the top of the fenders til I can find a 48-50 box, needs brake shoes and drums turned, no headliner or anything like that, its got a seat out of some little chrysler car, needs another radiator or this one repaired ( before the front sheetmetal was on kids were twirling wire around and punched it full of little holes [​IMG]) likely a ton of things I can't recall but its close to driving once its got brakes and a radiator
  26. I had a '54 Chevy truck that had sat ffor years...ddid a tune up and fired the 235 right the hell up! Ran so smooth an quiet that you couldn't even tell it was running when the hood was closed!! I liked the 235, that AntiC had, so much I took it off his hands! That motor was/is STRONG! I did, however, p*** it along to another friend...but only beccause I have bigger, meaner plans for the jalopy!! Muwahahahaha! No replacement for displacement! I think you've just had some bad luck...stick with it!
