Buick 300 small block
Discussion in 'The Hokey Ass Message Board' started by 29 rattrap, Apr 28, 2009.
  1. 29 rattrap
    29 rattrap
    from New York
    Will an intake for a 215 aluminum block fit a buick 300 motor?
  2. fms427
    fms427
    Nope - not even close. 300 intake forms the valley cover of the engine - 215 does not (a**** other differences). If you are looking for a good 4bbl manifold for your 300 - use a 64 aluminum factory manifold - fairly easy to find, and fits later cast iron heads - contrary to some info around.
  3. Limey Steve
    Limey Steve
    Alliance Vendor
    from Whittier
    No the 215 takes a steel intake gasket that covers the "valley" the 300" has the manifold made to cover the "valley" under the intake . 4 barrel manifolds are out there I found one for Carol's Fordoor & I do have a 215 engine .
  4. 29 rattrap
    29 rattrap
    from New York
    damn, i wish i could find some cool speed parts for my 300
  5. fms427
    fms427
    I think you're pretty much out of luck - I don't know of any multi-carb manifolds that are available for the 300.:(
  6. 29 rattrap
    29 rattrap
    from New York
    ill probably end up putting a 4 barrel intake on it and run it the way it is for now
  7. fms427
    fms427
    215 finned rocker covers fit - that'll help somewhat !!:D
  8. HEATHEN
    HEATHEN
    from SIDNEY, NY
    What year is the engine? '65-'67 300s have cast iron cylinder heads and the intakes interchange for those years, but the '64 300s with aluminum heads are a one year deal.
  9. 29 rattrap
    29 rattrap
    from New York
    my motor is out of a 65 special
  10. BrandonB
    BrandonB
    from nor cal
    Use the 4 barrel intake with a 2x2 adapter.
  11. 29 rattrap
    29 rattrap
    from New York
    where would you go about getting a 2x2 adapter?
  12. BrandonB
    BrandonB
    from nor cal
    Speedway has them for $89 plus shipping.
  13. 22rdstrguy
    22rdstrguy
  14. 29 rattrap
    29 rattrap
    from New York
    looks like im going with a vintage style y adapter from vintage speed, so i dont have to spend more money on a four barrel intake and still have the 2x2 setup.
  15. repoguy
    repoguy
    If you're ultimately looking to wake up a 300, I'd go over here:
    http://www.buickperformancegroup.com/
    ...and find Sean Etson. He has what is probably one of the fastest 300 powered Buick Specials in the country, and supposedly is the guru for making these engines come to life. he knows all the tricks. I think his car runs in the 11's or low 12's, and I believe it's a street car.
    He may even have the intake maniflold you need.
  16. 29 rattrap
    29 rattrap
    from New York
    i dont need that much power. The motor is going in my model a so even in its stock form it would move the car along nicely, i just want a cool multi-carb set up.
