shoebox vin# question
Discussion in 'The Hokey Ass Message Board' started by clifforddean, Apr 30, 2009.
  1. clifforddean
    clifforddean
    My 49' Ford has a vin# on ***le but cannot find a # under hood that matches. I think there is a patent plate but that # does'nt match. Will this be a problem if I sell vehicle?
  2. Jack Luther
    Jack Luther
    Best reference I know is the 1949-50-51 Ford Book, published by the Early Ford V-8 Club of America. Hopefully it's still in print.
  3. RenoRat
    RenoRat
    from Oxnard,Ca
    There is stamped numbers on the cowl that indicate year,model,color,ECT but on the right side of the firewall there is a rivited plate that has the vinn# on it
  4. Tommy's Cycle
    Tommy's Cycle
    from So Cal
    The serial number is also stamped on the p***enger side of the frame. You can buy a new patent tag from Dennis Carpenter and have your local trophy shop stamp your VIN/serial number and remount it on the firewall. Don't confuse the cowl number with the serial number, they're not the same.
  5. Johnny1290
    Johnny1290
    I can clear this up for you real quick. If the patent plate # doesn't match , then your ***le doesn't match the car, the end.
    Michigan doesn't check the vin against the ***le, so getting registration is not a problem.
    The PO must not have had a ***le for it and just bought a 'historical do***ent' and used that.
    How do I know this? I bought a car out of Michigan and the ***le didn't match the VIN, live and learn.
    I went the extra mile and filed for a lost ***le when I got the car here in california, I just didn't liek the idea of fooling with VIN plates and whatnot, and it was only $150 to get the whole thing straightened out.
