Projects A Natural Disaster: 1964 C10
Discussion in 'The Hokey Ass Message Board' started by muddpile, Jan 9, 2009.
  1. HRK-hotrods
    HRK-hotrods
    Very cool... I had a "spare" 3 door 'burb body laying around that I was going to do the same thing with, but built as an exhibition wheelstander. Got tired of the clutter and sold the bodyshell...
  2. Markster60
    Markster60
    from WI
    Way KOOL I have been thinking of similar project for years.
  3. Taff
    Taff
    it's a great looking truck, before the rear-engined aspect come's into play, nice idea and very well executed, congrats on that.just a suggestion, but i would put a plain cover and tailgate on the bed, then under the hood i would put a stock 350 SBC, that had blown up. look cool at shows with a rod or two hanging out of your "motor"!
  4. flynbrian48
    flynbrian48
    Hands down the coolest project posted here in a LONG time. I gotta ask about that 2x4 intake (maybe you said, but I didn't see), is it a stock iron one you've used or aftermarket alum?
  5. Gizzy
    Gizzy
    from N.W,Ohio
    Hmm....I like it.I could easily see it in Hot Rod in it's dare to be different section. Giz'
  6. muddpile
    muddpile
    from Canada
    Wow do you guys have some ideas, from one end of the spectrum to the other, I like it!
    I've got about 8 months into it, but they were LONG nights, and every night sort of thing. The research aspect as well was a HUGE hurdle. Ever had to explain why you need a 14 ft throttle cable, 18' choke cable, or a reverse pattern TH400 shifter? Yeah...... Haha.
    The intake is an old Offy 360 dual quad aluminum. It has a pair of 500 carter AFB's on it, and it will wear a pair of chrome helmets with spike nuts. Right now it has an Edelbrock 650 on the stock Toro intake with a 1" spacer and 1" adapter to clear the linkages (the stock toro intake is super-low).
    I won't weight the front end, as it drives good now. The front inner fenders are un-modified, and the tires are about 3/4" away from them, so it rubs on large bumps. I will look after that problem this winter.
  7. Kruzer63
    Kruzer63
    Lookin good buddy, glad to see that you cant hide how sick and twisted you really are... everyone knows now haha!!
  8. Steve O
    Steve O
    I saw this link on cl***icoldsmobile.com
    I had to join here just so I could tell ya I think your truck is cool:cool:
    Im a ******** Olds guy, I think it needs another 455 in the front;)
  9. Roadsir
    Roadsir
    Long winters bring out the best. I think it's cool.
    Get one one those plastic small block chev mock-up motors for up front, Drive into an event with a couple of plug wires pulled, Get out, piss and moan about how ****ty it's running, throw a fricken fit, open the hood and yank the motor out and toss it 20 feet.:eek:
  10. 38Chevy454
    38Chevy454
    I like it a lot. Your progress is definitely going the right direction. Not sure if the 425 trans uses the same converters as a regular trubo 400 does, but you could always take your converter to a converter shop to be rebuilt with higher stall speed.
  11. nailheadroadster
    nailheadroadster
    Now that's thinkin outside the box... er, I mean outside the engine compartment.
  12. ****in Canadians!
  13. Cool as ****
    nice work
  14. flatheadpete
    flatheadpete
    from Burton, MI
    I think the young lady in your avitar looks sad?
    Anyways.....this thing kicks ***. When I was in high school, a guy had a VW bus with a Toronado drivetrain. Scary. It felt like it was gonna tip over all the time.
  15. muddpile
    muddpile
    from Canada
    No recent updates yet unfortunately, shop is PACKED with other stuff at the moment and I'm about 100 miles from it, but I will be firing up again shortly, as there are a few additions I want/need for this year.
    The 1968 (I believe) Toronado's had a switch pitch converter with a higher stall speed, so I'd love to find one of those, as this thing just doesn't take off the line like it should, mind you, it doesn't spin either.
    When I first started driving this truck, it had rear alignment issues... By issues I mean I might as well not have had a steering wheel, haha. When I figured I had it dialed in better, I took it for another try (this was MONTHS later). Knowing how it was before, I was almost ready to write a suicide note, you know, just in case it did what it did again to me... Luckily, my "do it yourself" tape measure/chalk line/transit/laser level alignment did the trick. It doesn't even cut tires! Keep in mind, I did this because no alignment shop will touch this truck, but that's fine with me, as doing it myself I know it's done to my personal preference.
  16. jchav62
    jchav62
    Just came across this one. WICKED!!!
  17. Plowboy
    Plowboy
    Neat! You should fill the engine bay full of Subwoofers they way all the mini tuckers fill their beds....ha ha ha
  18. KING CHASSIS
    KING CHASSIS
    I like this thing. I like the idea of another motor in front! POWERING THE FRONT WHEELS!!!!
  19. RichG
    RichG
    Wild little ride bubba! Very nice repairs on some serious hillbilly car art. Whatever you do from here is gonna make it that much sweeter, be sure to post more pics!
  20. Racrdad
    Racrdad
    "no alignment shop will touch this truck" I can imagine the look on their faces! haha
  21. Kruzer63
    Kruzer63
    Rumour has it the old boy is workin on this truck again and no longer a 100 miles from it!!! Im anxious to see the new updates Muddpile has added now!!
  22. muddpile
    muddpile
    from Canada
    cancelled
  23. Mattilac
    Mattilac
    muddpile's truck even got to star in a recent music video!
  24. cool build indeed
  25. muddpile
    muddpile
    from Canada
    Haha, true enough, where'd you see the video at? It's on Youtube and I believe Bravo on television. Being in a music video is one experience I would totally relive.
  26. H3O
    H3O
    how well does your cooling system work?
  27. 57JoeFoMoPar
    57JoeFoMoPar
    Not feeling the song, but your truck looks awesome in the video!
  28. BigRed390
    BigRed390
    *****in! Love it! Wondering if I could do the same with an FE and one of those newfangled 6 speed Ford GT transaxles......... $$$$$$$$$$$$$
    Love the truck though! That's got to be the best head-turner you'd ever come across.
  29. PRIMERDAVE
    PRIMERDAVE
    this thing is Badd ***.....
  30. muddpile
    muddpile
    from Canada
    The cooling system works good actually. On the highway the fan is on, in town it's off. It has to be filled through the neck in the top of the hose, but aside from that, it's good to go.
