1959 Rambler Engine Swap.....
Discussion in 'The Hokey Ass Message Board' started by gasser55, Jan 1, 2009.
  1. gasser55
    gasser55
    I started a build thread on the rotary wagon i'm building for ramzoom...So I thought I would share some pics of the 59 were working on.
    Been working on it for a few days and makeing alot of progress.......The old engine and ****** has been pulled to make room for a DOHC quad 4 engine and four speed transmission.The engine has been rebuilt & painted along with the front suspension.I should be able to have the new engine set in place by the weekend so I can start fabing the mounts. I will post pics as the work gets done.
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
  2. ***Area-51***
    ***Area-51***
    from Ohio
    COOL, bring it on.....
  3. Animal
    Animal
    I'll be watching this closely. I'm going to be putting a turbo 2.3 in a '60.
  4. OoltewahSpeedShop
    OoltewahSpeedShop
  5. ramzoom
    ramzoom
    Got some more parts....bolted up bellhousing and trans for mock up..setting motor to make mounts and check clearances...
  6. Ruiner
    Ruiner
    1st, you failed to mention it was supercharged with Mikuni carbs, COOL! 2nd, is that an Eaton M90? 3rd, how did you get around the stock torque tube rear axle?
  7. Man, talk about thinking outside this box! This is great. Keep the info and pictures coming!
  8. ramzoom
    ramzoom
    Oh yeah its supercharged:). It is a Eaton M62. The carbs are Keihin 50mm siedrafts. Keeps getting more interesting huh! More progress in the next week or so. There is no torque tube on an American..just the bigger Ramblers...
  9. That's a cool project right there now! Should be a peppy little ride ..
  10. Edian
    Edian
    from Idaho
    so anything new on this? love the m62 and mikuni's, there's a standalone timing computer our there somewere, and its not that miuch if you ahvent figured out the ignition yet, hope this is going good:), good luck
  11. Shaggy
    Shaggy
    from Sultan, WA
  12. gtnrkix
    gtnrkix
    Nice! Love them old Americans. Wasn't Choprods building an American wagon or ranchero/camino a while back?
  13. ramzoom
    ramzoom
    Some more progress..........
  14. OoltewahSpeedShop
    OoltewahSpeedShop
    Love it.... Keep up the progress pics.
    Kevin
    Ooltewah Speed Shop
  15. jakespeed63
    jakespeed63
    Hey Zoom, you are truly a man of vision! Would love to go for a ride when it's done :cool::cool:
    JT
  16. Chaoticcustoms
    Chaoticcustoms
    Probably should paint it red with a ferrari powerplant instread.
  17. ramzoom
    ramzoom
    Actually were going to paint a Ferrari Green with a Rambler powerplant instead..try to be different:D Besides tune ups would cost awhole lot less!
  18. ramzoom
    ramzoom
    Blower intake started and tensioner and alternator in place. We are going to build a box to raise the blower a bit. Electronics for spark are mounted in the old fan area of the firewall.
  19. Pir8Darryl
    Pir8Darryl
    That is just too cool! Looks like it's fitting together quite well. Should be a fun little ride!
  20. Chaoticcustoms
    Chaoticcustoms
    thing is just freakin cool.
  21. yorgatron
    yorgatron
    that thing is super *****in' but please tell me you aren't gonna use the original front suspension :rolleyes:
  22. ramzoom
    ramzoom
    Yes we are keeping the original front suspension..swapping the front suspension on a Rambler American is a pain. The front end in this car is in pretty good shape and they are pretty strong. I did not want to cut the car up under the hood which is what one usually must do to swap the drivetrain. I wanted to be able to convert a Rambler to something modern without major cutting. As you can see we did not have to change the front suspension, cut the inner fenders, firewall, or trans tunnel. If you want to see a cut up Rambler check out my rotary powered American wagon:) This car is being modified purposely without major cutting if poss. The wagon is a differentt story....
  23. ElPlymino
    ElPlymino
    from Orcutt
    ramzoom, are you using the original rear springs with that Ford rearend? I was thinking about using an S-10 axle under my 54 Rambler.
  24. ramzoom
    ramzoom
    Yes the stock rear leaf springs are staying
