Brake fitting?
Discussion in 'The Hokey Ass Message Board' started by PBRmeASAP, May 6, 2009.
  1. PBRmeASAP
    PBRmeASAP
    Anyone have any idea if something like this is made? I've checked almost everywhere local and all the big parts stores online....
    I need one simular to the pic, but both ends need to be male threads. one side 1/8 NPT and the other side needs to be 3/16 flange (bubble) MALE. I'm drawing a blank look on almost any parts stores faces, checked all the hardware stores and searched online....pulling my hair out because this is the only thing keeping me from driving....
  2. Special Ed
    Special Ed
    Have you checked Earl's Performance Products online?
  3. Solidaxel
    Solidaxel
    What are you trying to make ?
  4. Goztrider
    Goztrider
    from Tulsa, OK
    Years ago, my dad was looking for a similar part, but it needed to make a 90* bend going into the caliper on the front of my RPU. However, nothing existed, so he wound up having to take a Tee fitting and braze one end/side of it closed.
    Wonder if that'd be possible with what you're working on?
  5. ProEnfo
    ProEnfo
    from Motown
  6. cornfieldrodder
    cornfieldrodder
    Any decent Parker-Hannifin dealer should have them. You may have a Motion Industries or Berry Bearing in Milwaukee. NAPA stores that cater to agricultureral areas may also carry them.
  7. Retro Jim
    Retro Jim
    A good old time parts store will have them . Most new parts store **** !
  8. 35Chevy.com
    35Chevy.com
    from New Jersey
    Try Home Depot
    Gary
  9. by bubble do you mean a metric bubble or a jic fitting. jic stuff is either a hydraulic shop or earls/russell. first pic is a metric bubble and the second is a male jic to male pipe.
  10. vertible59
    vertible59
    Try Dorman Products.
  11. JohnEvans
    JohnEvans
    from Phoenix AZ
    Or if the flare angle is 45* it would be a SAE flare.JIC is 37*
  12. true the double flare is a SAE 45*, i was thinking he was maybe talking about an AN fitting which is a 37* JIC.......i could be wrong though :D.
  13. willymakeit
    willymakeit
    Try a large truck brake and front end shop
  14. Paul2748
    Paul2748
  15. Paul2748
    Paul2748
    Looks like a fitting for a brake residual pressure valve. Most good parts stores should have it.
  16. TRUCK_RAT
    TRUCK_RAT
    from tulsa
    go to oreileys ask for a flaring tool give them about 25 bucks and then remake the ends on whatever you're doing so they aren't weird. i crawled under cars for two days looking for a very specific piece i needed and then i bought a flaring tool and it took about 3 minutes to finish everything.
  17. 29nash
    29nash
    from colorado
  18. oilslinger53
    oilslinger53
    from covina CA
    if you can't find the one, get the two, and braze them together. grind, polish, done.
  19. PBRmeASAP
    PBRmeASAP
    Sorry for not adding all the info needed....I have a thru frame fitting for running the brake lines. Both sides on the thru frame is 1/8 NPT, the fitting in the pic is works for the hard line coming in, my problem is the other side that connects to the rubber brake line(heading the the wheel cyl). before using the thru frame thing, hard line went straight to the rubber line, no problem....with the thru frame thing, now i had to get adapters to match up the lines. I believe the McMaster-Carr fitting 50635K371 is the ticket.
    I think problem solved....
  20. i don't think that's gonna work for you. you said it was hard line into rubber hose before and all you added was a through frame fitting. you need a male inverted flare to pipe fitting. it also needs to be male to male which i think is going to be odd.
    check out the br*** catalog and it tells you what each style of fitting is.
    http://www.eatonhydraulics.com/products/fluid_conveyance_weatherhead.htm
  21. chickenridgerods
    chickenridgerods
    from DSM, IA
    Keep in mind that the "bubble" flare is not the same thing as the good ol' 45-deg inverted flare. The bubble flare is used typically on metric-sized line on modern vehicles. You need to be sure what style you need before you start buying parts; the flares aren't interchangeable.
