Lowering a ´56 Premiere
Discussion in 'The Hokey Ass Message Board' started by Lincoln, May 2, 2009.
  1. Lincoln
    Lincoln
    Hi,
    two years ago I rebuild the shock absorbers of my 56 Lincoln. How I have to admit that the rear leaf springs are to weak. I want to brink them to a blacksmith to bring them back in shape.
    I´m also thinking about to lower the car about 2". Could anyone say where I get new and lowered shocks and coils springs?
    Thanks and greetings from germany
    LG
  2. bct
    bct
    if you are only dropping it 2 inches you could cut the front springs . probably less than one coil...for the rear you could make 2" lowering blocks...take your springs to a commercial truck spring business...they can work wonders ...
  3. PeteFromTexas
    PeteFromTexas
  4. 58Darlene
    58Darlene
    Try Jamco suspension.
  5. bgbdlinc
    bgbdlinc
  6. Winged Avenger II
    Winged Avenger II
    from Wisconsin
    cut the coils to rest at 3 inches
  7. hombres ruin
    hombres ruin
    Dont heat the coils...cut them..56 lincoln is gonna look evil lowered.
  8. Those are good lookin' cars...post pics after you drop it...JAMCO by the way
  9. low-lincoln
    low-lincoln
    I lowered mine in the rear with 2 inch blocks & took out the two smallest leafs. I also added the "air over leaf" setup from Air Ride so I can adjust the reat about 3", trust me...you need it, the rear will drag on any steep drive way. I cut 1.5 coils off the front coils. This made my 56 sit pretty level with the rear a smig lower than the front. You can look at my pics if you want, it think it sits right, but lower would look even better.:D Post some pics. There's not many 56 Lincs out there.
  10. low-lincoln
    low-lincoln
    Almost forgot, lowering the rear can make it a real chore to get the rear tires off, the flat lip where the skirts sit does not give you much room. A slighty smaller and narrow tire will help me when I need to replace my WWW's. Good Luck!
  11. I have a 57 in the shop right now that lays on the frame, and chopped 4 inches. you could use it for a coffee table
  12. Lincoln
    Lincoln
    Thank you for all the answers. Hmm, but if the front/rear springs are lowered, aren´t the shock absorbers compressed too much?
  13. Comet
    Comet
    Yeah. You'll need new (shorter) shocks as well more than likely.
  14. Bad Bob
    Bad Bob
    from O.C. Baby
    It can be done!!!! This one's bagged,but just wanted to show you a LOOOOW one!!!
  15. MERRELL
    MERRELL
    i used 91 aerostar springs up front on my 56 merc,theres a couple threads about it on here...
  16. Hot Rod Michelle
    Hot Rod Michelle
    Any more pics of lowered Lincs?
  17. low-lincoln
    low-lincoln
    Here's another pic, its about 2.5" lower all the way around.
  18. Lincoln
    Lincoln
    Jamco said, that I could use the present shocks. Hm I´m not shure that it works.
    Here are two pics of a ´56. The red one is my Lincoln.
  19. Retro Jim
    Retro Jim
    I think you can use the same shocks , but if it was mine , I would use lowering block in the rear and cut the springs in the front !
    BUT first consider where you drive the most and where you part your Lincoln . Check the dip if you park in a driveway ! Also the road rash can kill you !
    Have fun and post some pics of your Lincoln ! :D
  20. Lincoln
    Lincoln
    Hi,
    after rebuilding my power steering pump, two new hoses and a chromed fluid reservoir I get back to my idea to lower LP.
    On the right&left side of the car, runs a angle(?) (on the picture where green meets white) from the front to the tail. I think when the car was new, that line was straight. Now the rear is lower (from the ground to that line are 69,5cm/27") than the front (71cm/28") AND the rear driver side is lower than the right (68cm/26,7").
    So where to start? Front or rear?
    Jamco Suspension is able to manufacture new coil springs which are lowered 2" and I found a company to rebuild the leaf springs.
    I want the car equally low or the front a little bit lower than the rear.
    So if anyone has an idea, let me know.
    Lennart
  21. Lincoln
    Lincoln
    The leaf springs are rebuilt.. but not ***embled again.
  22. Lincoln
    Lincoln
    Time to post again...
    the company that tried to rebuild my rear leaf springs make something very special: After ***embled them I realized that the car was higher than before. Lucky me.
    So I ordered new lowered springs from Jamco Suspension. That was in february. After waiting now for more than three month they still not arrived. My questions, why it took so long, are not answered from Mr Genty.
    So maybe next year (or never) I could show you my Lincoln. Lowered.
