One for the Rocketeers
Discussion in 'The Hokey Ass Message Board' started by redoxide, Sep 21, 2004.
  1. redoxide
    redoxide
    Is there a manual gearbox conversion for the 53 Olds 303 engine.. ? Ive got a hankerin to build a G***er style rod based on this engine .. I have the auto trans and by all reports it works well enough but i dont know squat about the box... and if it went BANG where i would get a replacement.. ( check my location) Im planning the project round a 34ish Austin Ruby body just for a bit of FUN.. Its not to be a race car just a looker.. P.S any pics of similar brit bodied g***ers would be greatly appreciated ..
  2. yorgatron
    yorgatron
    do you have a bunch of extra cash laying around? all that stuff is hard to find,and expensive to boot.'53 is a good year for the dual-range hydra-matic.i'm running a slant pan in my '54,and my brother has a '53 303 and hydro in his '51 hudson.try top find the original band adjusting tools,change out the fluid regularly,and make sure you have the throttle and kickdown linkage adjusted correctly,and you'll be fine.a bone stock hydro will chirp 2nd gear at full throttle,a fully modified hydro set up for drag racing will get rubber in all 4 gears.read up on them here; www.rodnkustom.com/rocketeers/hydramatic/index.html i love'em [​IMG]-george
  3. leadsleadolds
    leadsleadolds
    Have you checked Tanson Enterprises give them a call there web site has no info but its www.forwhatyouneed.com I emailed em and there sending me a free catalog. But I know they do ****** work and conversions.
  4. yorgatron
    yorgatron
    Tanson? **** THAT ****!!! that's for people that have jetaways or slim jim trannies.don't be a candy *** run the cast iron hydro
  5. redoxide
    redoxide
    Yorg. Thanks for the info Saved the page and will get into it later tonight .. I heard that the old box was a strong unit but wondered about its reliability now it gettin on ... Thanks again..
  6. RocketDaemon
    RocketDaemon
    from Sweden
    1950 olds manual with a hurst magic shifter
    rocks!
    or caddy 1950-1953/1954 manual (same different tailshaft though)
    these ******s are the SAME as lasalle/caddy used in the 40ies..
    bolt on to your olds 303 without modification
  7. weemark
    weemark
    from scotland
  8. RocketDaemon
    RocketDaemon
    from Sweden
    wasn't that discontinued?
  9. 56olds-ERDY
    56olds-ERDY
    you could start with the auto,and move to the manual when you get the parts togather if you choose.i think a manual would be fun in a car like that.the nice thing is the crank already uses a pilot with the auto soo you can just slip the manual in if you feel like it later.thats if the auto is in decent shape.then your project wouldnt bog down trying to find hard to find parts.you may find a complete setup,but it might be cheaper buying the stuff seperatly,and i didnt think wilcap offers anything anymore either for the early olds unless they updated recently.
    eric
  10. yorgatron
    yorgatron
