Can you piant over duplicolor spray paint?
Discussion in 'The Hokey Ass Message Board' started by dannyego, May 12, 2009.
  1. dannyego
    dannyego
    My car is currently in primer. I had to buzz it back down because over winter some snow got in my garage and sat on the primer and it started to rust again in a few places. I still have some body work to do but I would like to drive it this summer and work some of the bugs out and pull it apart again over winter to finish the body work. I have rattle canned flat black some cars to flip, and although it doesnt look as good as a real paint job it helps keep the moisture out. I was wondering if I were to spray bomb this car for the summer if I would have to strip it all off before its final paint job or could I just knock it down a bit and paint over it? I know a lot of you are going to say finish the body work and then paint it but I really dont want to sit on the sidelines another summer.
  2. OshkoshRob
    OshkoshRob
    from Oshkosh
    Everytime I have tried to paint over spray paint I have had problems....lifting, wrinkling, fish eyes, etc....
  3. so.ill.
    so.ill.
    dont do it u will, make tons more work for yourself.
  4. dentprone
    dentprone
    Yeah, you will definitely be sorry later if you do.
  5. pasadenahotrod
    pasadenahotrod
    from Texas
    Spraycan primer does not seal out moisture, only finish paint does that.
    I wouldn't spray anything over spraycan primer except more spraycan primer or spraycan finish paint.
  6. Cirilian
    Cirilian
    It'll all have to come off before you paint it.
  7. SlowandLow63
    SlowandLow63
    from Central NJ
    Yep. IMO, nothing that comes out of a rattle can is good enough to put expensive paint and time on top.
