Hot Rods Oh No I F$%*ed up!!!! Ansen Wheel Help Needed!!!
Discussion in 'The Hokey Ass Message Board' started by JeffreyJames, May 4, 2009.
  1. 327-365hp
    327-365hp
    from Mass
    I was wondering what the advantage is to using WD-40, water works fine for me and is much easier to clean up.
  2. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    You know, I would love to give you a great answer but like I said I have never done this and the friend that welded up the chips recommended that I use WD-40. Perhaps for a lubrication so that the Aluminum does not get to hot? Not sure, but when a man as talented as Scott talks to a hack like myself I listen intently.
  3. Chris
    Chris
    I thought you were going full show??? Fully polish them ****ers :D
    Front AND back ;)
  4. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Hahaha Chris. I want the car to be more go and slight show that's why I did not want to polish them. More of a car that cleans up a bit on the track and looks good doing so rather then one that gets polished every other day to keep up it's charm.
    I may have no other choice though. The fronts are looking pretty polished already so I think I'll leave them alone.
  5. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Oh and I have polishing spokes so I forfeit the idea right from the get go.
  6. SLO POK
    SLO POK
  7. B.A.KING
    B.A.KING
    i read somewhere that cadium gold spray paint will match. i think they sometimes use on hood hinges or such. but its been a while since i read it and may have forgotten. i've had a drink and taken pharmasuticles:D since i saw that. but that is what i had planned on useing .eastwood maybe?
  8. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    I scrubbed the other wheel center down with the Steel wool and made it uniform. They looked good as is but I wanted that color. I found a duplicor that I am going to dust on there and see what I have. The color looks like it's going to match perfectly so I should have the pics in a day or two. None the less I am less worried then I was when I started this thread. The wheels are going to look great I think.
    The rim sanded to 2000 looks great, I can't imagine what it's going to look like once I get the polish and ball out. Lug Nuts are my real issue right now. Need to find some nuts that look the part and period.
  9. Dunno if this helps.
    I believe these are Mr. Gasket open lugnuts.
    I cut them down for clearance underneath my 34 V8 re-pro caps on my slot mags.
    Wheel mit cap.
  10. B.A.KING
    B.A.KING
    there is something about that color on the wheel that just screams hot rod.
  11. JeffreyJames
    JeffreyJames
    from SUGAR CITY
