i lowered the bracket for max clearance and plumb some temp lines to see how it moves i have to make lower plates and when im happy il weld them permanently
Whats up Joel great forum, great work keep up the hard work You never stop even back in the days in the streets of Brooklyn you were doing your thing. keep it going my brother, any help just call.
ok the update for today i got allot done i purchased two tubes 1-1/2" x 3" x 3' i made the ch***is level, clamped the beam in place, drilled holes for bolts (so when i remove and reinstall for final fit it will sit in the same place ) marked where the contact areas are for welding, grinded all contact area and rebolt tube and weld the **** out of it in that order are you ready for more pics?
thanks for the help jesse and ray ok i welded the first seam them folded the metal over and welded the last seam i think its stronger then the factory ch***is in this area i will use high grade bolts for the holes
ok i feel the ch***is is done i will start to degrease and paint and install front airbags. i removed old inner fender wells and radiator support as i should be using the old stuff for this. i also have to clean up the engine and throw some new gaskets on the block. did you know i will have a/c,cruise control & power steering here what it looks to start with the next pics it should all be done so it will be a while
Are you going to add a shockto it,I feel you should put some shocks to get a better ride ,im doing it on mine (food for though)
yeah i will put shocks i have to relocate them a bit i need a new front bag as one of mine has a leak anyone have an extra bag Firestone 255c Air Bag 2500lb Single 3/8" Port
ok yesterday i removed the nose of the car in one section so after i place the body on the new ch***is (before bolting in place ) i can place the nose for reference here its is wrapped around a tree as a joke
yeah brother, you got heart. like how you got things going and how its gonna look, im doing a 52 plymouth. not sure what way im going to go yet, frame swap or do brakes in front and rear axle swap in rear. right now, im going to not notch my rear frame. im sitting 5 inches off ground from bumper bottom to floor, but i got old huge tires on it so, im working on that. great inspriration. keep up the great work and pics. metalplate matt
thanks guys i wanted to let you know positive comments do help its nice to see thanks again lonebker i was going to do a four link in the rear but i didn't like the disk brake kit for my car it different parts from cars to make my kit and fatman front cost more then my donor car plus its a four door so no loss in value here
ok cleaned the underside i did not undercoat yet still have welding to do i placed the body on the ch***is and everything went perfect as planed except for the supports i welded in the a-pillar i forgot about ch***is clearance so thats going to get redone i also will have to gut the whole trunk sheet metal as it was worst then i thought after cleaning the underside the orig undercoat was holding it together but the rockers i welded in held the car perfect i could open the doors while it was in the air no problem i have to find so projects on here where the fabricator welded all new floors to get some ideas on how im going to hit the trunk area are you ready for more pics i have been at it since 8 a.m.
You should be an inspiration to all the whiners who say they cant do anything with thier cars cause thier shop isnt big enough etc, keep at it you will be driving before you know it!!
Joel, you have done great! In the time you have taken to get this far, I haven't done a darn thing. I'd say something like I can't wait to see this done, but you are kicking **** already, especially in those conditions! Hats off, thumbs up, atta boy, righteous dude and three cheers!
lol thanks man my plan now is to modify the 2x2 steel i welded in the wrong spot so the front fire wall sits lower so i can put body mounts then i have to figure what type of body mounts im going to use/make starting from front and working my way to the back the entire trunk floor is garbage so i will redo it once she is bolts straight to the frame so its going to be awhile so until next time
i have a minor problem with the floor supports i replaced with square tube cause they raise the body of the frame an extra inch so i either make up the difference or remove them and redo it so the body sits lower im not in a rush as this is very important step right now like i said before im not a professional and its only me working on it if i had more people i would have more ideas on hand so i am looking at all my options and will use the best ok so i have the body centered front to back spare fender for mock up mock up of front body mounts i kinda wish they where lower
i was thinking of cutting out the floor supports from the old floor and extending the ones on the car and eliminate the square tubes but i wont get that much differance in hieght unless i body drop it which i don't want to do i hate when the floor are uneven so im leaving it at the height she's at and will start to fab bdy mounts tomorrow i need a break and yes there is a whole complete car and a half of another in my shed of parts
Why dont you notch that section and cut the tube smaller to lay lower, if not try to find a smaller body mount.
this is turning out nice and it started worse than mine. how did you do all the bends on that rocker? both mine are rusted out but i wasnt sure how the do the tight three bends in the middle.
ray take a trip out to my house and show me what your talking about, are you going to jaydens birthday party im 2 min from marvs house or call my house thats just a sample i had made up i will take better pics for you its not hard the rocker will be two parts three if you want to make it really strong an outer skin , center structure, back side
you have impressed me!!!!! no garage, leaves, covering the parts and the tools, you must have very understanding neighbors. and on top of it all your going to have a great car. ..........Well dont stop now !!!!!!!!! get done so I can stop reading about yours and go work on mine
For what it's worth between the stock car guys and rust in general those Monte Carlos have apparently become damned hard to find - enough that we sold one with weak rear frame rails to a guy who spent another $1000 or so to have it shipped from New York to Louisiana. There might be some resale value in your leftovers. Which, the rear frames in these rot so much I'd be hesitant to use one under another car.
