Need Help in ID'ing Engine Code Stamping Numbers
Discussion in 'The Hokey Ass Message Board' started by High Class Rat, May 16, 2009.
  1. I have a Chevy V8 small block engine with the front engine code stamping numbers of 19J112956 V09T7FB and I am having problems identifying it. The rear stamping cannot be read due to the placement of the firewall/engine. I have been to several websites, but the numbers don't seem to match up. Can anyone help?
    Thank You
  2. 32v
    32v
    from v.i.
    fb is 1955 265 155 hp
    or 1969 327 255hp
    wayne
  3. propwash
    propwash
    from Las Vegas
    if 32v is correct - then if you HAVE an oil filter flange - you must have the 327, if there's no provision for an oil filter on the block driver's side - then it is a 55 265
    dj
  4. 32v
    32v
    from v.i.
    the 55 also would not have provision for side mnts
  5. Yes, it's a 327. Thank you all very much. Is it possible to tell from the front stamping what vehicle it came out of. I was told a corvette, but everyone with a 327 seems to say that.
  6. bob41
    bob41
    engine suffix code fb is a 1969 327 with powerglide in a full size car, got this off nastyz28 web site ,hope this helps .
  7. squirrel
    19J****** means it's a Chevy car from 1969 (or 1979) made in Janesville
    can't be a 79 because the FB suffix is only two digits, that makes it 1969 or older.
    so yeah it's a 69 327.
  8. nitrohonkey
    nitrohonkey
    What are the casting numbers on the back?
