I have a 1953 chevy that starts great when the motor is cold , after driving awhile ill shut it down and it wont re start for the life of me ??? just wondering if anyone has had this problem ? thanks .
ive changed the entire ignition system already , points , condenser , coil , plugs , wires , cap , rotor , and installed a 6 volt altenator . i just dont get what else can be wrong ???
Could be the starter getting hot. Could also be a vacuum lock in your fuel line if its to close and getting hot.
I had a similar problem with my 54 235. I had a badly adjusted choke. With the low 6 volts and lousy ignition it was a pain in the *** to restart at times. I quickly fixed that problem by going 12 volts and HEI ignition. She starts quick and runs great.
I have had a similar problem with fuel puddling in the intake. I had to rebuild the carb an adjust the float. Next time you go out for a drive, pop the carb off the intake and see if you have gas puddled up in the bottom of the intake. Once you get home of course! Just something to check.
Looks like the answers are all over the board. I just fixed one of these for a friend after a rebuild. The valves are too tight. Loosen them up and check it out. The valves are ok cold and when hot they stay open not allowing the engine to start....
Is the heat riser on the exhaust manifold stuck open? What about the Heat riser for the choke and is the choke adjusted properly?
Had a similar problem with mine. turned out the valves were sticking. The symptems: not starting after warmed up and shut down (cranking but not starting) untill about an hour went by it would start right up. Also I installed a temp guage and found that it was running way too hot. put some Marvels in tank and sloshed it around and it wasnt an issue anymore...also ran normal temps. Hope this helps.
Have you tried, holding the pedal to the floor, while cranking??? Mine does this too, thanks to ol faithful roch-b
hot coil?? i just remember my aunt used to have that prob so she would carry a bottle of water soak a rag wrap around the coil and it would start. might be something to check, i dont remember what she did to actually fix it though
