torsion bars for roadsters
Discussion in 'The Hokey Ass Message Board' started by FTF, Sep 20, 2004.
  1. FTF
    FTF
    Anybody have any information or plans using torsion bars for a roadster? My plan is to copy somewhat the instant roadster that was built by Dragmaster and published in the Feb, 1964 issue of Hot Rod.
  2. Roth used to use Volkswagon front ends with some sucess.
    You can also use a digger front end. If you shop around you can find them pretty cheap.
  3. Roothawg
    Roothawg
    Don't ask Rashy ....he don't know Jack. [​IMG]
    I have some old Hot Rod mags you can rummage through if ya want.
  4. I'll be using 29" sprint car bars, arms, and stops on all four corners of my T-bucket. I have enough left over from my racing days to do this. It won't be like the old Dragmaster setup however. Bars will run parallel to the car centerline and will connect to the split 'bones in front and under the banjo axle in the rear.
  5. FTF
    FTF
    SJFast, do you have any photos? My idea was to use the same mounting as you have planned. How is the spring rate figured? Will you be mounting the arms with shackles or direct. When I lived in Duluth they said it was colder by the water, nice city, I miss it.
  6. FTF
    FTF
    Rash is one sick pup
  7. Roothawg
    Roothawg
    Is this a dedicated drag car or a street car FTF?
  8. Roothawg
    Roothawg
    Not sure what you guys are building but I tld Rashy I would post pics of this a while back but never could find em.....
    Jerry Browns car
  9. old beet
    old beet
    Torsion bar rear in this street/strip "T" since 1964.......OLDBEET
  10. FTF....sorry, no photos. The car is still an Autocad image. I'm not sure if I'll use shackles at the torsion arm ends or let the arm ends ride on rollers. Either way will work. Perhaps I'll hand draw a sketch.
    Yeah...."Cooler by the lake" is something we hear all summer. Of course, in the winter the lake keeps us warmer most of the time. [​IMG]
  11. Root...was that car called "Hot Chocolate" ? If it's the same car I have 8mm film of it on the return road at the '64 Indy Nationals.
  12. FTF
    FTF
    Thanks for the replys and photos, the plan is to build a copy of the Stanford drawing on page 85 of the twenty fifth issue of Rodders Journal. Altered wheel base race car for the street and a little fun on the strip. Should be able to build on the cheap, will use Rash as gofer and human "C" clamp. I have most of the parts from my 23 after it was wrecked so a body and some tubing is about all I need. Been going over several web sites Sprint cars, american track roadsters.com etc. but most don't really show much.
  13. CURIOUS RASH
    CURIOUS RASH
    Classified's Moderator
    <font color="green">ROOT,
    You know you love me, and don't try horning in on FTF. HE'S MINE!
    FTF is dead serious about this thing and I can't wait to get started on it. He has hunted down everything ever printed about this car and studied it in detail and you're right, compared to FTF, I DON"T KNOW JACK!
    </font>
  14. CURIOUS RASH
    CURIOUS RASH
    [ QUOTE ]
    [/ QUOTE ]
    <font color="green">That's funny ****!!!
    At least you have learned my abilities/limitations! [​IMG] </font>
  15. 22 track
    22 track
  16. 22 track....that's very much like what I'll be running.
  17. CURIOUS RASH
    CURIOUS RASH
    <font color="green"> BTTT for FTF, He's on Dial-Up! </font>
  18. burger
    burger
  19. preferolschool
    preferolschool
    from Dallas, TX
    Does anyone have any information for calculating spring rate? Got a chart with spring rate for various diameters of material? Advantages to material -- chromoloy or tempered mild steel?
  20. KlunkyMcShift
    KlunkyMcShift
    I think you'd be better off checking out midget/sprint car sites for that info. Most still use t-bars. Also 1960 to 1962 chevy trucks use t-bars up front. Awesome smooth ride.
  21. Years ago the Carrera shock absorber people had a chart that would show the spring rate of a certain diameter and effective length torsion bar at whatever length of arm you design to.
    I have one around here somewhere.
  22. laverda
    laverda
    I have found a couple of resources....
    Torsion bar calculator
    Torsion formula
    I keep seeing inexpensive torsion bars, stops, etc on eBay and wonder if I could use them on the A sedan. I also have been surprised how many guys used the torsion bar setup in the 50s ... most of the drag racers anyway. Thanks for the all the info, good thread.
    later
    PS is there a good reason to avoid the eBay items? ... they are often ex-racer stuff. Maybe the rates would be suspect/inconsistent &amp; that is the reason behind the racer boy auctions.
  23. CURIOUS RASH
    CURIOUS RASH
    <font color="green">Good info guys, thanks.
    I talked to FTF and he has tweeked his back pretty good so he may not be sitting at the idiot box too much right now.
    I will let him know there's a bunch of info flying, keep it coming.
    RASHY </font>
