Loading a car with no wheels
Discussion in 'The Hokey Ass Message Board' started by rollin63, May 19, 2009.
  1. rollin63
    rollin63
    I just bought up another 1932 Chevrolet 5W Coupe yesterday and I need to go pick it up here in the next couple weeks. The car has a full frame but the rear end and front suspension is all gone... just frame, engine, and body. I am wondering if anyone has any tips or tricks on how to get a car that has no wheels onto a trailer without damage to the trailer or car. Fortunately the previous owner has it on cinder blocks so it is not down in the dirt. Any suggestions would be helpful. Thanks.
    matt
  2. Von Rigg Fink
    Von Rigg Fink
    from Garage
    slide it up on 3/4" thick plywood
  3. hotrodladycrusr
    hotrodladycrusr
    I'd get 4 wheel dollys and put each corner of the frame on one.
  4. fiat128
    fiat128
    from El Paso TX
    Get a pair of old rear ends with wheels on them and u-bolt them to the frame
  5. Killer
    Killer
    forklift... tractor... a few friends to pick it up?!?!!
  6. The37Kid
    The37Kid
    Welcome to the HAMB! get 2 4x4 that are 2 feet longer than the trailer width. Place the 4x4 under the ch***is side to side and carefully lift the body & frame tall enough to back the trailer under. Bring along lots of blocks or two floor jacks. WATCH what is going on at all times, have some friends help.
  7. northerndave
    northerndave
    from Badger MN
    does the dude have a loader tractor?
    cause if he does, the first thing you do is shoot the tractor.
    from there, ya just take your time, don't get in a hurry. You can use some lumber to help ramp/skid it up.
  8. The37Kid
    The37Kid
    Another thought is just put a rear with wheels and tires on it and pick up the front and "Wheelbarrow" it around. Movinmg stuff that is heavier than you is fun.
  9. DirtyThirty
    DirtyThirty
    from nowhere...
    Yeah...The Dollies, baby! They're irreplaceble. Like stated above, you'll use them down the road too...
    Just might need to chain/strap them on, because they sometimes like to go shooting out!
    They are fairly inexpensive.
  10. Chris
    Chris
    I did this once, but it was a 39 Merc fordor! I got two floor jacks, jacked the front end up as high as it would go and put blocks under it (about halway back). Back the trailer under it and let the front end down. Then jack the back end up and block it at the very rear. Place a floor jack under the front (so it rolls) and back the trailer in as far as you can/ Place a pipe under it about half way back, let it down, and with the pipe and the floor jack under the front it will winch right up were you want it. It was super easy, and only took about 1/2 hour to load.
  11. kwoodyh
    kwoodyh
    Have a double helping of Wheaties for breakfast! What ever you do it ain't gonna be easy!
  12. havi
    havi
    Welcome!! I dragged an F1 frame onto a snowmobile trailer using a come-along, and a pair of boards as levers. If I had to do that over again, I'd go with a pair of mobile home axles and wheels to slide underneath (the old ones). Even a 2" steel tube poking through a pair of wheel hubs is better than nothing. Anything to overcome the friction.
  13. pasadenahotrod
    pasadenahotrod
    from Texas
    Now folks, do you believe a car with no front suspension or rearend is actually in a place that those wheel dollies would function in to load it?
    Best thing is a good come-a-long and a 51 Merc hood or two. SLide a hood under the front frame rails, block up on 2x4s or a piece of 3/4" plywood under each rail end for skid, do the same at the rear. Back the trailer up so the ramps can be slid together to the width of the frame plus a little. Lay plywood down on the ramps. Hook up your come-a-long to the front frame crossmember of the car and start cranking.
    You'll know what to do.
  14. Von Rigg Fink
    Von Rigg Fink
    from Garage
    its hard to explain..but i get ya..see post #2
    its already elevated up on blocks..this just makes life easier for the slide it on plywood deal
  15. Little Wing
    Little Wing
    from Northeast
    You put PT 4x4 or a 6x6 between each dollie laying teh car frame on the 4x4/6x6
  16. whatever
    whatever
    ive used a truck hood slides like ****er
  17. Von Rigg Fink
    Von Rigg Fink
    from Garage
    those late 70's chevy pick up hoods are great for that **** arnt they?
  18. whatever
    whatever
    76 my man lol
  19. havi
    havi
    (O/T) used one to haul our fish-house through town 2 miles to get to the lake.
  20. Bring a box of Kleenex for the Merc lovers....:eek::D
  21. hugh m
    hugh m
    from ct.
    And that's what I like about America!
  22. Four empty oil drums high enough to clear the trailer height.
    Two hunks of steel to place on the drums and bridge over the trailer.
    Portable engine hoist.
    Get each end of the car high enough to get the body/frame up on the steel bridges.
    You'll need to do some interim steps so you don't get the body at such an angle it will slide off.
    Back trailer under car.
    Lower car body/frame onto trailer.
    A sheet of plywood between trailer floor and body/frame will help when off loading.
  23. mottsrods
    mottsrods
    What he said, or make you some dolly's with pneumatic tires so they roll better on the dirt. I got a set with 10" tires i got from HF, and they'll roll anywhere.
  24. bubba57
    bubba57
    from k
    I'd go with the chevy truck idea. Cheap and easy.
  25. The37Kid
    The37Kid
    WHAT????????? The world ran out of useless AD Chevy truck hoods??:eek::eek:
  26. rollin63
    rollin63
    Thanks everyone for the quick replies! The car is currently on gravel, although it is level, I don't think that conventional dollies will work well. Maybe if I laid down plywood? I think that I am going to try to use some pipe as rollers and a come along. I like the pneumatic tires idea, I may have to go to a hardware store and see what i can come up with. Thanks again.
  27. rcoffey
    rcoffey
    here are some pics of me & my son loading the fairlane up .It had flat tires and the brakes were locked up.blocks,jacks,comealongs,water or gateraide save the beer for when you get it home. it was hot as all get out. bring some chains and tie downs too.
  28. LowKat
    LowKat
    This one had front wheels but same principle.
    Jack car up .
    Throw some wheels, blocks, firewood etc on the ground
    Stick a chunk of lumber across wheels, firewood, blocks
    Back trailer under car as far as possible.
    Come-along, winch, lever into position.
  29. :D That works - I have used the rear axle trick to move one with no engine/no trans/no FEA
  30. hotrod-Linkin
    hotrod-Linkin
    sky hooks work well.
    seriously,put it on the old chevy truck hood, a little axle grease on the floor and away you go.
