Projects Progress on Rocky's 34 coupe..last update 9/30/2020
Discussion in 'The Hokey Ass Message Board' started by Rocky, Jan 12, 2009.
  1. jangleguy
    jangleguy
    Right you are, Trent!
  2. Rocky
    Rocky
    Classified Editor
  3. NoSurf
    NoSurf
    word.
  4. hot rod pro
    hot rod pro
    from spring tx.
    rocky,i was looking at your pictures and saw that you had the floor panel on top of the subrail.on a 34 roadster we are working on,the floor is below the subrail.i don't know how much it will affect it,but you may want to look at that.
    here are some pictures that may help you.feel free to contact me if i can help.
    -danny
  5. Uptown83
    Uptown83
    I guess the body would sit a hair lower now since you put the floor on top of the subrail but you can see that he has the bolt through the frame and subrail on the side of the frame like its suppose to have. So it might be fine. I would bet it is.
  6. 40StudeDude
    40StudeDude
    Hahahahahahaha...works for Dan and I...I'm never wrong...!!!
    R-
  7. Rocky
    Rocky
    Classified Editor
    We put the floor on top of the subrail for a very important reason that's so cl***ified I really can't go into it....very hush-hush so don't spread it around, ok? Shhhhhhhhhhh....
    But thanks a ton for the photos...I was not aware there was a floor/b pillar gusset. My car is an old race car and as such, there's a lotta stuff like that missing. I'll whip up a pair of those babys....thanks again.
  8. lowsquire
    lowsquire
    from Austin, TX
    Danny,
    I just came across this, and those photos are exactly what I needed to put the floor in a 34 roadster.. Thankyou!
    whats the story with that car? wood doors? could it be an australian car exported back to you?
  9. six pack to go
    six pack to go
    from new jersey
    I am in need of these braces, are these origional or can I order thes post....If not, I will just make them...really want the stock look. PM me or just post here. thanx ~E
  10. GRADY
    GRADY
    WOW
    Looking awesome Rocky
    you going to be able to get away for Back to the Fifties this year?
    keep up the good work
    grady
  11. Corn Fed
    Corn Fed
    Rocky, those gussets are roadster only. Coupes didn't need them since the roof keeps the top of the post from moving around.
  12. Blakmerk
    Blakmerk
    from St.Joe MO
    Hmmm Sounds Delicious...
  13. fab32
    fab32
    Rocky, Good to see some progress on the coupe. Think you'll get to drive it this summer? Just a quick "round the block" would be just the ticket to keep the juices flowing over the winter.
    Frank
  14. Double ditto to what Frank said....
    Keep at it, one of these day's I'll find that 3 window...
    Cheers,
    Drewfus:)
  15. vwhabit
    vwhabit
    WOW! Body work being done! Excellent!
    Driving target date yet?
  16. jangleguy
    jangleguy
    To quote our wise old father, "Sheeeit! That engine ain't got enough gow to pull a sick ***** off a pisspot!"
  17. RocketDaemon
    RocketDaemon
    from Sweden
    Straight30weight likes this.
  18. Rocky
    Rocky
    Classified Editor
    Got some great stuff done last night. My new doors came in and I had 'em hot tanked to see just how good/bad they are. They have some light dent/rust damage and will require inner and outer door bottoms but hey, where do you find cherry 34 ford coupe doors?
    We tacked the doors in place to establish correct cowl/door molding lines and began fitting the quarters to the car. As was said earlier, the new SAR quarters are for roadsters and are about 1.5" longer than coupe doors so we had to "trim" them at the door jamb...I was about ready to ****, watching Jimmy cut into my brand new 1/4 panels but he's a pro...knows his **** and I'm just his helper at this point. BTW, the SAR parts are very, very nice and they have all the body lines in the correct places..makes it fairly simmple to trim them to fit. We got the driver's side fitted and tacked into place....got about 80% of the p***engers side done before it got late. Next friday, we finish up the p***enger quarter and by then the top should be outta the hot tank...ready to begin fitting it. It's slowly beginning to look like a real 34 ford coupe body!
  19. Rocky
    Rocky
    Classified Editor
    The important part was to get the body lines to line up. We can adjust door gaps later on and we gotta install new door bottoms so we can adjust door bottom to rocker gaps then... here's a little look at the misalignment of the gaps at the bottom of the p***enger door...all adjustable later but by God, we got those damn door lines lined up!
  20. Rocky
    Rocky
    Classified Editor
    I busied myself punching holes in the inner trunk piece so we can rosette weld it to the trunk floor when it's time..damn! I love all this shiny new metal!
  21. Rocky
    Rocky
    Classified Editor
    My body guy, Jimmy is a perfectionist and as such it takes him a long time to get his customer's cars done and out the door.....means he has very time to play with his own stuff but he has been taking soem time to put together a shop truck of his own. He's NEVER put his name on any of his personal vehicles but he had his shop name put on the back window. When he FINALLY gets the pickup box done, it's gonna be a super nice truck.
  22. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    rocky... this is gonna be a nice one... keep up the rad work. I keep looking for updates! Nice to see the progress... man o man I'm excited for you.
  23. Rocky
    Rocky
    Classified Editor
    Thanks, Jeff.....each Friday I get a little more excited too. Wish I had more time to work on it.
  24. Rocky
    Rocky
    Classified Editor
    chopping the top and installing it is next....should be out of the dip tank by this coming Friday to begin the installation. Jimmy said he'll be using an old corvair top for an insert...here's how the top looks today
  25. tattedfordguy
    tattedfordguy
  26. bobby_Socks
    bobby_Socks
    from ǑǃƕǑ
    I think that I live in a cave sometimes, this is the first that I have seen of this build. It is looking very nice and looking forward to the next update.
  27. Rocky
    Rocky
    Classified Editor
    Puttered around on my 46 chevy pickup in the parking lot for awhile and I came in the shop and helped my bodyman take the cut-off 34 top down from the rafters and we placed it on top of the body....supported by the door-tops. The doors are from a 4 door sedan. Neither of us had a clue the 4 door front doors were almost 2 inches taller than coupe doors. I just thought the door tops had a little different angle at the back of the tops but nope, they're also taller. I used my hokey-*** cell phone [forgot my digital tonight] to record the goofy looking top. This baby is "anti-chopped!".
    The top takes a little trip through the stripping vat this coming week and we'll get really serious finishing up mounting the 1/4 panels and chopping/mounting the top.
  28. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    oh... hell.... yeah!
  29. Mat Thrasher
    Mat Thrasher
    Wow it's coming together fast, looks great.
    Mat
  30. ss34coupe
    ss34coupe
    Rocky, this thread I began sometime ago has some discussion about using four door doors on a five window coupe, and the modification that are required. They will work. Looks like you are making great progress!33-34 Ford coupe bodies - THE H.A.M.B.
