Narrow wheels ??
Discussion in 'The Hokey Ass Message Board' started by 29mike, May 21, 2009.
  1. 29mike
    29mike
    Can the temporary spare steel wheels usually found on an s10 blazer be used as a full time wheel ? Mine are stamped 16 x 4t, but, i'm hoping the " t " designation does not mean the welds won't hold up over time. Looking for an answer before i invest in the new cokers. Thanks..........mike
  2. The wheel should be fine. It's the tire that won't last.
  3. Bettlejuice
    Bettlejuice
    from WV
    Up here where winters suck somethin' fierce, lots of people use spare tire wheels for mounting snow tires, since they're skinny and cheap...
  4. RoadkillCustoms
    RoadkillCustoms
    from Mesa, AZ
    Harrison speaks the truth. Replace the rubber and you'll be fine.
  5. 29mike
    29mike
    i was hopin for these kind of answers............mike
  6. Hackerbilt
    Hackerbilt
    Won't an S10 4x4 Temp wheel be deeply inset? The road wheels are.
    (The ones I have had or worked on all had full size spares so I don't know the Temps at all...)
  7. bsmdeuce
    bsmdeuce
    I used a set of them on an s-10 with bias tires that I drove every day.Brock
  8. k-member
    k-member
    I have a pair of a 98-02 Lincoln 16" inch aluminum spares on the front of my Studegasser...should work out with decent tires.
  9. Retro Jim
    Retro Jim
    The tire is the only problem ! They make great gasser wheels !
    I also have a nice pair for the front of a project .
