Biggest tire for 15x10 steel wheel
Discussion in 'The Hokey Ass Message Board' started by SquigMachine, May 23, 2009.
  1. SquigMachine
    SquigMachine
    wanting to know whats the widest tire i can run on a 15x10 steel pickup wheel...heard way to many things from way to many people and wanted to see if someone here can give me a solid answer
  2. Fordguy78
    Fordguy78
    I've seen 15 inch wide tires on a 10 inch wide wheel. It worked out pretty good on the back but I definately wouldn't run them on the front. Also, you probably shouldn't go any wider than 15 inch.
  3. stillkruzn
    stillkruzn
    from Conway, AR
    I am running a 285/70 15 on the rear of my Model A on a 15x10 wheel....
  4. RickyRodder
    RickyRodder
    I think the widest you'll probably find is 295/50R15 for a 10" wide wheel. I had them on my old Monte Carlo SS. They're pretty wide. Looked really good.
  5. hotroddon
    hotroddon
    Depends on the tire. Height, saidewall construction etc. I run 14X31 Firestone Dirt Tracks on my 15X10's and the tire measures out at 14 1/2" wide.
  6. Memph
    Memph
    from Washington
    FWIW 29X15.50-15LT Mickey Thompson Sportsmans are approved by them for 10 inch wheels.
  7. same here
  8. SquigMachine
    SquigMachine
    Yea this is going on my 55' pickup...Sweet 295/50/r15 sounds good but so does a 14X31 Firestone Dirt Track(hmmmm some cheaterslicks would be choice)
  9. Me too.
  10. da34guy
    da34guy
    If ya can find 'em
