Taking leaves out of a 49'
Discussion in 'The Hokey Ass Message Board' started by clifforddean, May 24, 2009.
  1. clifforddean
    clifforddean
    I'm using 2" blocks and I took 2 leaves out of each spring, the springs are pretty much flat almost negative arch. Anybody do this with no problems or is 2 to many.
  2. HotRodRick49
    HotRodRick49
    What '49 is in question? If it's a Shoebox Ford, I'm also interested in knowing how to do this.
  3. yamadafacka
    yamadafacka
    which leaves did you take out??
  4. 52style
    52style
    id like to know this too a 49 what???
  5. e z i
    e z i
    His profile says he has a 1949 Ford business coupe, so I'm guessing
    that's what he's talking about?
  6. pasadenahotrod
    pasadenahotrod
    from Texas
    You always keep the main leaf and #2, then remove odd numbered leaves. It takes experimemntation to find the right number but it is worth it.
  7. i will go on record and say i'm not a big fan of removing leafs from springs to make them sit lower. i really believe you are better off having the springs de-arched and keep the full spring pack to give support when it is needed. that doesn't cost a lot of money. about $100. this `49 ford has stock rear springs with all the leafs that were de-arched and has no lowering blocks...yet.... of course , what do i know......
  8. clifforddean
    clifforddean
    Sorry bout that ezi figured that out like a champ. Anyways I took out the 3-4. Still rides decent what I'm concerned about is any driveshaft problems, u-joint angles look alright not sure about slip yoke.
