Projects Newbie just shook hands on a 53 Chieftain
Discussion in 'The Hokey Ass Message Board' started by Kinghat, Apr 12, 2009.
  1. Chief 53
    Chief 53
    from Canada
    Great to hear there are more 53 chieftain guys out there.
    Congratulations and you're going to love that car.
    I have a 53 Chieftain Canadian and although it doesnt look exactly the same as your's it is a Chieftain.
    Mine is not stock by any means with a 10 bolt posi, 300 hp small block and 700R4 trans however the steering and brakes are origional with a couple of changes.
    I have lowered spindles from Fat Man Fabrications and the brakes were just re done to use a dual master cylinder with no power ***ist.
    The brake hoses and lines have definatly been replaced and the master is a 1970 Mustang Disc/Drum master.
    I got a master cylinder bracket from ECI Hot Rod components and the job was really quite easy.
    Its still frame mounted and if a big block 60's Dodge can stop with manual drum brakes so can I.
    The brake cylinder components and ***orted parts are still on Rock Auto and I find the part numbers there and either order them from there or cross them at my local auto parts store.
    I find a lot of parts for my car by searching 53 Chev as Pontiac stuff is harder to find but I always have to verify the part numbers.
    I'll check back here and am looking forward to more pictures of your restoration
