1957 gmc 9300
Discussion in 'The Hokey Ass Message Board' started by roadrash, May 27, 2009.
  1. roadrash
    roadrash
    Question for the inliner experts. I have a '57 9300 GMC (Canadian) ,having trouble identifying the engine casting #....C 232869.....head casting # 3836848 ....my thinking is it's a 261 but not sure . Have checked several sources with no luck ,any help would be appreciated !
  2. Old61
    Old61
    from PA
    270 or 302. I think you may be missing a # on the engine casting
  3. panic
    panic
    That's definitely a Chevrolet head casting, very common.
  4. roadrash
    roadrash
    Had that idea too......rechecked block and vin tag match ......# C232869....my understanding is the GMCs made in oakville have chevy engines in them ,likely has something to do with this different casting number .
  5. mr57
    mr57
    If it's Canadian built GMC it will be a 261.....
  6. Gigantor
    Gigantor
    Not to hijack, but as long as the subject has come up, will a 270 GMC flywheel fit a GMC 302, and if so, does anyone know where I can get one?
  7. It depends some have 4 bolts and some have six. Most 302 have the six bolt flywheel. OldWolf
  8. Gigantor
    Gigantor
    Thanks Oldwolf. My 302 has 6, but I was told many moons ago that a 270 would bolt right on. Even if the inside diameter of the crankhole will fit over the large 302 crank, I could tap the necessarry holes. But I've tried several GMC and Chevy flywheels and they're all too small. Having a hell of a time finding the 270 flywheel.
  9. nickpayton
    nickpayton
    from a
