Drop springs or drop spindles??
Discussion in 'The Hokey Ass Message Board' started by GRADY, May 27, 2009.
  1. GRADY
    GRADY
    I have a 1963 Impala that originally had a 327 and a four speed
    those are long gone and it now has a GM crate 383 that is a lot lighter than the original cast iron 327 is....the result with out pics..sorry still at work..is that my front end sits a lot higher than I want...much like mustangs
    lol
    I am looking into either a) getting drop spindles
    or b) buying drop springs
    both of these are available in a two inch drop although I could go three inch drop in with springs....
    i do know that afterward I will need to balance tires and camber
    just wondering what has worked best with you all out there
    I do want to stay away from air bags atm if at all possible
    thanks again I will sit back and watch what comes back to me
    :D
  2. BigBlockMopar
    BigBlockMopar
    Dropped spindles will maintain the car's full suspension-travel (unless something else hits the ground first ofcourse), so no camber adjustments are needed.
    Why do you think the tires would need to be rebalanced? They don't need to.
  3. satan's childs
    satan's childs
  4. 51 MERC-CT
    51 MERC-CT
    Raised spindle supports:):D
  5. GRADY
    GRADY
    forget the rebalancing wheel
    thinking too hard
    lol
  6. Steves32
    Steves32
    from So Cal
    Best way-
    Drop spindles.
    Maintains full suspension travel & geometry.
    Traditional way?
    Wack a coil or 2 off. ;)
  7. hombres ruin
    hombres ruin
    Dropped spindles full travel and i never looked back
  8. GRADY
    GRADY
    Was leaning towards them because the ones I have my sight on can be easily run disc brakes
    it would be very nice to stop my 3600 425hp car quickly
  9. Is the 383 all aluminum or something? If it's a GM crate motor, than probably not. At the most, maybe it has aluminum heads and intake. The 383 can't be that much lighter than the 327. After all, they're both small blocks right? I would go with the drop spindles, but if you want to go even lower you could run both. The new drop springs will probably be stiffer and feel better than the mushy, old, worn out springs. You might not have to have to get an alignment as long as the new spindles are quality castings, and you don't use drop springs as well. If they are straight, and all mounting points (ball joints and tie rod) match factory specs, the camber & caster should stay the same.
  10. GRADY
    GRADY
    Yeah...it is the ZZ383 with aluminum heads
    since I have had it is though the front sits higher
    put new springs in the rear hoping to move the *** end up but that did not work
    also do not want to cut coils
    but thanks guys
    just had not made my mind up yet
  11. 52style
    52style
    balance tires for drop springs WTF ??!!
    I THINK SOMEONE BLEW SOME SMOKE UP YOUR ***
  12. chickenridgerods
    chickenridgerods
    from DSM, IA
    Do note that using the dropped spindles will negate your ability to use the stock drum brakes, if you still have them. If you currently have a disc brake conversion, some of the spindles will make the parts you have now incompatible, too.
  13. pasadenahotrod
    pasadenahotrod
    from Texas
    Go use your local auto parts store(CarQuest, O'Reilly's, NAPA) MOOG new coil spring catalog. Look up the new springs for for your car front and rear. Then go to the back of the book and look under the correct chart for specifications. You'll find new springs with same wire size, end configuration and spring rate but shorter free height.
  14. Marty McFly
    Marty McFly
    Drop spindles from Superior Spindle.
    I put Superior Spindles on my '62. I ordered them with the 12" Camaro 1LE rotors and calipers-> don't get there bearings they are Chinese ****. The only bummer is metric wheel studs, no standard size will fit without machining the holes. I used to have the spindles that use the 10.5" S10 rotors but sold them to a buddy because I wanted the bigger 12" GM brakes.
    Marty McFly
  15. atomickustom
    atomickustom
    I'd start with new springs and see where that gets you. If your front end is lighter (and therefore higher) you need SOFTER springs to put it back where it was before the motor swap.
    You don't need special dropping springs or dropped spindles unless you're trying to make it sit lower than it did with the original motor. Cutting the springs you have will just make it that much stiffer.
    If you want to go lower than it was, then replace the springs with softer ones and go with dropped spindles. If you just want to restore the ride height you had, then it's all in the springs. (Dropped spindles and the springs you have will give you odd geometry in your front end.)
  16. devilscustom
    devilscustom
    from Sweden
